Hello everyone! I've been trying for a few days to solve this one problem, but nothing seems to be working. I've tried reading other posts with similar issues and implementing the solutions proposed therel but still can't figure out what i'm doing wrong since the code does not work the way i intend it to. I'm hoping a more experienced used can help me out.
Here's the issue:
As part of a larger project i'm writing a piece of code that involves two LEDs and should do the following:
-If LED1 is on, then turn on LED2.
-If not, LED2 is off.
I managed to get the first part working, but afterwards, even if LED1 is turned on I can't get LED2 to do the same. Suggestions?
Here's the code:
int led1 = 12;
int led2 = 8;
int led1state;
pinMode(led1, OUTPUT);
pinMode(led2,OUTPUT);
int state = Serial.parseInt();
if (state== 2){ // turn led1 on
digitalWrite(led1,HIGH);
led1state=digitalRead(led1);
while(led1state==HIGH){ // turn led2 on while led1 is also on
digitalWrite(led2,HIGH);
if (state==3){ //turn led1 off
digitalWrite(led1,LOW);
led1state=digitalRead(led1); // update while condition to break out of the loop if no longer true
I've tried using break; inside the if statement, but it yields the same practical result: LED2 does not turn off even if LED1 does.
Thanks in adavance!
SOLVED
Working sketch follows
int led1 = 12;
int button = 11;
int led2 = 8;
int led1state;
const unsigned long interval = 5000;
unsigned long currentM= 0;
unsigned long previouscheckM =0;
void TimeCheck(){
if(millis()-previouscheckM>=interval && digitalRead(led2)==HIGH){
digitalWrite(led2,LOW);
Serial.println("off");
pinMode(11,INPUT_PULLUP);
int state=Serial.parseInt();
if (digitalRead(button)==0){
digitalWrite(led2, HIGH);
Serial.println("on");
previouscheckM=millis();
TimeCheck();
if (state== 2){
if (state==3){
digitalWrite(led2, LOW);
