While loop falsely ends...
In the following code, the while loop only runs once, then stops?
//declare variables
int TX_LED = 3;
int RX_LED = 4;
int LC_LED = 5;
int LC_IN = 0;
int AB_IN = 1;
int MB_IN = 3;
int AMP_RELAY = 6;
int loadcell;
int ampbatt;
int mainbatt;
int compread = -1;
int compCONNECT;
int count = 0;
Serial.begin(9600); //Begin arduino-computer serial communication at 9600baud.
//declare pin modes
pinMode(TX_LED, OUTPUT);
pinMode(RX_LED, OUTPUT);
pinMode(LC_LED, OUTPUT);
pinMode(AMP_RELAY, OUTPUT);
//turn on amp relay
digitalWrite(AMP_RELAY, HIGH);
//flash LEDs rapidly 3x
while (count < 4)
TX_FLASH(10);
RX_FLASH(10);
LC_FLASH(10);
delay(200);
count = count + 1;
while (compCONNECT = 0);
Serial.println(“12345”);
TX_FLASH(100);
compread = Serial.read();
if (compread > 48)
compCONNECT = 1;
RX_FLASH(100);
compCONNECT = 0;
int TX_FLASH(int time)
digitalWrite(TX_LED, HIGH); //turn on TX_LED
delay(time); //wait TIME
digitalWrite(TX_LED, LOW); //turn off TX_LED
int RX_FLASH(int time)
digitalWrite(RX_LED, HIGH); //turn on RX_LED
digitalWrite(RX_LED, LOW); //turn off RX_LED
int LC_FLASH(int time)
digitalWrite(LC_LED, HIGH); //turn on LC_LED
digitalWrite(LC_LED, LOW); //turn off LC_LED
First, use CODE tags when you post and refer to the sticky that you should have read.
Second, which while loop? You have more than 1...
Lastly:
if not the proper way to compare two values. The comparison operator is ==. You are using the assignment operator.
Also, the semi-colon after the while statement is what the while loop "sees" as the loop body. remove it.
KeithRB: Also, the semi-colon after the while statement is what the while loop "sees" as the loop body. remove it.
Good catch.
A couple of improvements:
Can be reduced to:
 void FLASH_SOMETHING(int led, unisgned long time)
  digitalWrite(led, HIGH);
  digitalWrite(led, LOW);
if (compread > 48)
I gather you aren't sending it 48, you're sending it '1', '2', '3', etc.? Functionally it's the same, but this is more clear as to your intentions:
if (compread > '0')
count = count + 1;
The language is called C++. Feel free to use such operator:
count++;
Can be reduced to:
Which the compiler will complain about, since it is missing a return type.
PaulS:
Can be reduced to:
No it's not... :zipper_mouth_face:
Thanks for the responses. Was very pressed for time and totally forgot about code snippets :( Also, very new to C++, very used to VB.net, so I was used to:count = count + 1 Will go through and change that. Arrch, thanks for bring those to my attention. Its works now :)
