While loop gets stuck
const float deltaTheta = PI/8000;
volatile float theta = 0;
  lineAndPause();
//  lineAndPauseHalf();
void loop() {}
// This first version works. It goes from zero to pi/4, pauses for a second, then goes from pi/4 to pi/2.
void lineAndPause()
  while(theta < PI/4)
    Serial.println(theta);
    theta += deltaTheta;
  while( PI/4 < theta && theta < PI/2 )
// However, the following second version gets stuck at pi/8. I don't understand why. Any insight, please?
void lineAndPauseHalf()
  while(theta < PI/8)
  while( (PI/4 + PI/8) < theta && theta < PI/2 )
works for me. reaches 1.57.
what do you expect your code to do after lineAndPause() completes and returns to setup()?
you’re loop() has nothing in it
Um, just uncomment the
lineAndPauseHalf();
that is the problem part.
The first function works, yes.
The second function (lineAndPauseHalf) gets “stuck” at 0.79 or pi/4.
In the problem function: at the end of the first while loop, theta is ~Pi/8.
The next while loop runs while theta is greater than Pi/8+Pi/4. It clearly isn't so it never does anything.
Ah, ok–thank you both very much!
Solution
  theta = PI/4 + PI/8;
  while( (PI/4 + PI/8) <= theta && theta < PI/2 )
That second while loop might as well be simply:
  while(theta < PI/2 )
