While loop inside another wile loop??
Hi, I've been fighting this for several days now and I'm no better off than I was a week ago.
My inner and outer loop both should work while there is Serial.available() > 0.
Below the inner while, there is a switch statement that is supposed to process after the inner loop is finished.
outside this inner loop, but still inside the outer loop, "Ready is set to true" then the switch statement for this outer loop section is processed; it is only activated once for each Mode and during the cycle only one Mode is set.
Both switch statements work on the Mode setting to get started.
What I'm seeing is that the second switch statement is executing before the first one is done. Sometimes with no data because the inner loop is not yet finished setting the data.
  1. Is it NOT advised to use and inner and outer while statement with the same conditions for looping??
  2. Is the buffer for the Arduino Due/2560 this happens on both boards, expandable and where might I find this option??
  3. does the the serial stream stop and start after it fills the buffer?? I'm thinking it should but not sure.
  4. The code is below. There are over a 1000 lines of code and declarations/definitions so am only showing the main code.
  5. This does compile on Due/2560 the problem is on both as well.
  6. I've added a monitor dump below code (partial) that shows the action being taken.
Thanks in Advance for any help or insights that you can provide.
  // Write Pin
  pinMode(0, OUTPUT);
  // Read Pin
  pinMode(2, OUTPUT);
  // Reset Pin
  pinMode(22, OUTPUT);
  //COM13 Serial between Arduino Due SAM3X and Serial Monitor.
  //COM9 serial between Due and Laptop Control Console.
  Serial1.begin(115200);
  while(!Serial){};
}//end setup
    // if there's any serial available, get the data group:
  while (Serial1.available() > 0)
    //=============================== start of outer while =============================
    //================================ Start of data retrieval==========================
    Ready = false;
      //============================= start of inner do while =========================
      //============================== Start of data retrieval==========================
      // look for the next valid groupname in the incoming serial buffer, and determine
      // the Mode number.
      Names = "MODECRegDFWFTW1FTW2FSKRROSKIMOSKQMOSKRRPA1PA2QDACUDCLKMQDACMPA1MPA2";
      groupName = Serial1.readStringUntil('\n');
      // get the startng position of the groupname.
      Pos = Names.indexOf(groupName, 0);
      if (DEBUG) {
        Serial.print("groupName = "); Serial.println(groupName);
        Serial.print("Pos = "); Serial.println(Pos);
      switch (Pos)
        case 0:
          Mode = Serial1.readStringUntil('\n');
          iMode = ConvertToInt(Mode);
          if (DEBUG) {Serial.print(" Mode = "); Serial.println(Mode);}
          // Should reset all address, ddata and length values again.
          //if (iMode == 0)ResetAllData();
        case 4:
          // get the data value and convert it to int. Same for all cases.
          CRAddress = Serial1.readStringUntil('\n');
          iCRAddress = ConvertToInt(CRAddress);
          CRData = Serial1.readStringUntil('\n');
          iCRData = ConvertToInt(CRData);
          CRLength = Serial1.readStringUntil('\n');
          iCRLength = ConvertToInt(CRLength);
          if (DEBUG) {
            Serial.print(" CRAddress = "); Serial.println(CRAddress);
            Serial.print(" CRData = "); Serial.println(CRData);
            Serial.print(" CRLength = "); Serial.println(CRLength);
        case 8:
             ... Same as above but with a different piece of dafta.
        case 11:
        case 15:
        case 19:
        case 24:
        case 29:
        case 34:
        case 39:
        case 42:
        case 45:
        case 49:
        case 54:
        case 59:
        case 63:
          MPA2Address = Serial1.readStringUntil('\n');
          iMPA2Address = ConvertToInt(MPA2Address);
          MPA2Data = Serial1.readStringUntil('\n');
          iMPA2Data = ConvertToInt(MPA2Data);
          MPA2Length = Serial1.readStringUntil('\n');
          iMPA2Length = ConvertToInt(MPA2Length);
          if (DEBUG) {
            Serial.print(" MPA2Address = "); Serial.println(MPA2Address);
            Serial.print(" MPA2Data = "); Serial.println(MPA2Data);
            Serial.print(" MPA2Length = "); Serial.println(MPA2Length);
      } // end of switch
    } //end inner while
    //Serial.flush();
    if (Serial.available() <= 0) Ready = true;
    //================================= End of do while ===============================
    //================================ Start of DDS Setup =============================
    if (Ready)
      if (DEBUG) {Serial.print("Mode = ");Serial.println(Mode);}
      switch (iMode)
        case 0:
          if (DEBUG) {
            Serial.println(" In Mode = 0 for SingleTone");
          SingleTone();
        case 1:
           UnRampedFSK();
        case 2:
          if (DEBUG) {
            Serial.println (" In Mode = 2 for RampedFSK");
          RampedFSK();
        case 3:
           Chirp();
        case 4:
          BPSK();
        default:
      }// end swiitch
      Ready  = false;
    }// End If
  }// End Serial Available
  //=============================== End of outer while =================================
  //================================ End of DDS Setup ==================================
}//end loop
partial monitor output showing how it jumps from Mode 1 beginning to set up data first 3 lines then the forth line with Mode = 1 not indented is in the second switch statement.
groupName = MODE
Pos = 0
Mode = 1
Mode = 1
In Mode = 1 for UnRampedFSK
Set function = CReg
addLength = 32 dataLength = 32
==> numBytes = 4
==> startPin = 23 bit = 29 ==> The read bit value = 0
==> startPin = 25 bit = 28 ==> The read bit value = 1
==> startPin = 27 bit = 27 ==> The read bit value = 1
==> startPin = 29 bit = 26 ==> The read bit value = 1
==> startPin = 31 bit = 25 ==> The read bit value = 0
==> startPin = 33 bit = 24 ==> The read bit value = 1
==> numBytes = 4
==> startPin = 24 bit = 31 ==> The read bit value = 0
==> startPin = 26 bit = 30 ==> The read bit value = 0
==> startPin = 28 bit = 29 ==> The read bit value = 0
==> startPin = 30 bit = 28 ==> The read bit value = 0
==> startPin = 32 bit = 27 ==> The read bit value = 0
ETC.
One more item: I've tried different baud rates on both serial ports. right now I'm on 9600 for Arduino to monitor and 115200 for laptop to Arduino. I've also completely reversed these to see little difference.
When I wrote a thingy for the DUE, I found this
did not work as well as this
while (Serial1.available() >= 1 )
I found the same issue with the STM32 Bluepill and kept the practice with the ESP32.
As a note uMT, a RTOS, runs quite well on a DUE and is a 'great' intro into freeRTOS, the ESP32 OS.
Here's the thingy I wrote for the DUE that makes good use of the serial ports.
#include <uMT.h>
#include <Wire.h>
#include "TFMini.h"
#include <Servo.h>
#include <SimpleDHT.h>
// scl pin 5, sda pin 4, vcc 3.3
// temperature, pressure, altitude, sealevelpressure
#define BMP085_ADDRESS 0x77  // I2C address of BMP085
#define BMP_Interval 65503
const unsigned char OSS = 0;  // Oversampling Setting
// Calibration values
int ac1;
int ac2;
int ac3;
unsigned int ac4;
unsigned int ac5;
unsigned int ac6;
int b1;
int b2;
int mb;
int mc;
int md;
// b5 is calculated in bmp085GetTemperature(...), this variable is also used in bmp085GetPressure(...)
// so ...Temperature(...) must be called before ...Pressure(...).
long b5;
const String sSeperator = " ";
Servo ServoLIDAR;
#define ServoLIDARPosit 1450
#define  byteServo_LIDAR_Pin 11
String sA = "";
//X Axis servo
Servo X_Axis;
#define byteXaxisServoPin 9
#define iX_Posit90 1538 //using writeMicroseconds
int iX_HowMuch = iX_Posit90;
//Y Axis servo
Servo Y_Axis;
#define byteYaxisServoPin 10
#define iY_Posit90 1492 //using writeMicroseconds
int iY_HowMuch = iY_Posit90;
TFMini tfmini;
// unsigned long lPreviousLIDAR_SequenceMillis = 0;
#define lLIDAR_SequenceInterval 50 // milliseconds
// 25mS is 40Hz
// 33mS ~30Hz
// 50mS 20Hz
// bool bBlankLIDAR = false;
#define byteUnoDataReady 22
// unsigned long lCurrentMillis = 0;
//microwave motion detector= iMW
#define MWM_PINin 34
#define MWM_PINout 36
// #define lLEDRateInterval 125 //milliseconds,  second
// unsigned long lPreviousLED_BlinkMillis = 0;
// bool bLedOnOff = false;
String sMessageToSend;
String sPi;
// bool bRcveDone = false;
// for DHT11,
//      VCC: 5V or 3V
//      GND: GND
//      DATA: 2
#define pinDHT11 2
SimpleDHT11 dht11(pinDHT11);
#define iDHT_Interval 60503
#define iDoVolts_Interval 45007
#define MINservo 1000
#define MAXservo 2000
#define SerialBaudRate 9600
#define Serial2BaudRate 115200
#define StringBufferSize 50
// bool bTask2Started = false;
#define EVENT_A  0x0001
TaskId_t iEvtID_A;
#define EVENT_B  0x0002
TaskId_t iEvtID_B;
#define EVENT_C  0x0003
TaskId_t iEvtID_C;
#define EVENT_D  0x0004
TaskId_t iEvtID_D;
#define EVENT_E  0x0005
TaskId_t iEvtID_E;
#define EVENT_F  0x0006
TaskId_t iEvtID_F;
#define  SEM_ID_01   1   // Semaphore id
#define  SEM_ID_02   2   // Semaphore id
#define  SEM_ID_03   3   // Semaphore id
#define  SEM_ID_04   4   // Semaphore id
// #define TIMEOUT_A
Stream* stream2Ptr;
  pinMode(40, OUTPUT);
  digitalWrite( 40, LOW );
  pinMode(byteUnoDataReady, OUTPUT);//setup interrupt pin as output
  digitalWrite(byteUnoDataReady, LOW);//set state initial
  Serial1.begin(TFMINI_BAUDRATE);
  // Initialize the TFMini LIDAR
  tfmini.begin(&Serial1);
  // Initialize single measurement mode with external trigger
  tfmini.setSingleScanMode();
  Serial2.begin( Serial2BaudRate );
  stream2Ptr = &Serial2;
  pinMode(MWM_PINin, INPUT);
  pinMode(MWM_PINout, OUTPUT);
  pinMode(LED_BUILTIN, OUTPUT);//blink LED at pin 13
  analogReadResolution( 12 );
  ServoLIDAR.attach( byteServo_LIDAR_Pin, MINservo, MAXservo );  // attaches the servo pin to the servo object
  ServoLIDAR.writeMicroseconds(ServoLIDARPosit);//sets initial posit
  X_Axis.attach( byteXaxisServoPin, MINservo, MAXservo );
  X_Axis.writeMicroseconds( iX_Posit90 );
  Y_Axis.attach( byteYaxisServoPin, MINservo, MAXservo );
  Y_Axis.writeMicroseconds( iY_Posit90 );
  Serial.begin(SerialBaudRate);
  // allocate a buffer in memory for these strings
  sMessageToSend.reserve( StringBufferSize );
  sPi.reserve( StringBufferSize );
  Wire.begin();
  bmp085Calibration();
  ADC->ADC_MR |= 0x80;  //set free running mode on ADC
  REG_ADC_MR = (REG_ADC_MR & 0xFFF0FFFF) | 0x00020000; // adc start up value
  // ADC->ADC_CHER = 0x80; //enable ADC on pin A0
  Kernel.Kn_Start();
} // setup()
  // if ( !bTask2Started )
  Errno_t error;
  TaskId_t fC_P;
  // fCheck_Pressure
  error = Kernel.Tk_CreateTask(fCheck_Pressure, fC_P);
  if ( error != E_SUCCESS )
    fKernalError( "fCheck_Pressure", error );
  // bTask2Started = !bTask2Started;
  Kernel.Tk_StartTask(fC_P);
  // fCheck_TH
  TaskId_t fC_TH;
  error = Kernel.Tk_CreateTask(fCheck_TH, fC_TH);
    fKernalError( "fCheck_TH", error );
  Kernel.Tk_StartTask( fC_TH ) ;
  // fCheckInputVoltage
  TaskId_t fDoVolts;
  error = Kernel.Tk_CreateTask( fCheckInputVoltage, fDoVolts );
    fKernalError( "fCheckInputVoltage", error );
  Kernel.Tk_StartTask( fDoVolts ) ;
  //  fDoLIDAR
  TaskId_t fLIDAR;
  error = Kernel.Tk_CreateTask( fDoLIDAR, fLIDAR );
    fKernalError( "fDoLIDAR", error );
  Kernel.Tk_StartTask( fLIDAR ) ;
  // fReadSerial
  error = Kernel.Tk_CreateTask( fReadSerial, iEvtID_A );
  Kernel.Tk_StartTask( iEvtID_A );
  // fDO_bRcveDone
  error = Kernel.Tk_CreateTask( fDO_bRcveDone, iEvtID_B );
  Kernel.Tk_StartTask( iEvtID_B );
  // fTweakServoX
  error = Kernel.Tk_CreateTask( fTweakServoX, iEvtID_C );
  Kernel.Tk_StartTask( iEvtID_C );
  // fTweakServoY
  error = Kernel.Tk_CreateTask( fTweakServoY, iEvtID_D );
  Kernel.Tk_StartTask( iEvtID_D );
  // fLIDAR_ServoAspectChange
  error = Kernel.Tk_CreateTask( fLIDAR_ServoAspectChange, iEvtID_E );
  Kernel.Sm_Release( SEM_ID_02 ); // release a single SEMAPHORE token
  Kernel.Sm_Release( SEM_ID_03 );
  Kernel.Tk_StartTask( iEvtID_E );
  // fSendOut_SEMAPHORE
  error = Kernel.Tk_CreateTask( fSendOut_SEMAPHORE, iEvtID_F );
  Kernel.Sm_Release( SEM_ID_01 ); // release a single SEMAPHORE token
  Kernel.Tk_StartTask( iEvtID_F );
  for ( ;; )
    if ( stream2Ptr->available() >= 1 )
    // if (Serial2.available() >= 1)
      Kernel.Ev_Send(iEvtID_A, EVENT_A);
      Kernel.Sm_Claim(SEM_ID_04, uMT_WAIT); // stop and wait for serial to be received and release of SEMAPHORE token
    }  //  serial available
    Kernel.Tk_Yield();
} // loop
void fKernalError(String sTask, unsigned error)
  Serial.print( " Tk_CreateTask(): " + sTask + " Failure! - returned " );
  Serial.println( error );
  Serial.flush();
  Kernel.isr_Kn_FatalError();
} // void fKernalError()
//   digitalWriteDirect / digitalReadDirect
// example: digitalWriteDirect(13, HIGH)
inline void digitalWriteDirect(int pin, boolean val)
  if (val) g_APinDescription[pin].pPort -> PIO_SODR = g_APinDescription[pin].ulPin;
  else    g_APinDescription[pin].pPort -> PIO_CODR = g_APinDescription[pin].ulPin;
// example: digitalReadDirect(12)
inline int digitalReadDirect(int pin)
  return !!(g_APinDescription[pin].pPort -> PIO_PDSR & g_APinDescription[pin].ulPin);
void fDoLIDAR()
  long iLIDAR_Distance = 0;
  long iLIDAR_Strength = 0;
  String sMsgToSend;
  String s_cm = "cm ";
  sMsgToSend.reserve( 16 );
  while (1)
    Kernel.Tm_WakeupAfter( lLIDAR_SequenceInterval );   // Wake up after ... milliseconds
    Kernel.Sm_Claim(SEM_ID_02, uMT_WAIT); // // stop lidar servo
    Kernel.Sm_Claim(SEM_ID_03, uMT_WAIT); // stop x y servo
    //    if ( !bBlankLIDAR )
    if ( digitalReadDirect( MWM_PINin ) )
      // if ( digitalRead( MWM_PINin ) == 1 )
      digitalWriteDirect( MWM_PINout, HIGH );
      tfmini.externalTrigger();
      iLIDAR_Distance = tfmini.getDistance();
      iLIDAR_Strength = tfmini.getRecentSignalStrength();
      if (iLIDAR_Distance < 600)
        // Serial.println( "TF Mini distance " + String(iLIDAR_Distance) + s_cm + " strength " + String(iLIDAR_Strength ) );
        // Serial.flush();
        sMsgToSend.concat( s_cm + String(iLIDAR_Distance) + " " + String(iLIDAR_Strength ) );
        Kernel.Sm_Claim(SEM_ID_01, uMT_WAIT); // // claim a single SEMAPHORE token
        sMessageToSend = sMsgToSend;
        Kernel.Ev_Send(iEvtID_F, EVENT_F);  // trigger fSendOut_SEMAPHORE + consume a single SEMAPHORE token
        sMsgToSend = "";
      digitalWriteDirect( MWM_PINout, LOW );
//      bmp085 functions
// Calculate pressure given up
// calibration values must be known
// b5 is also required so bmp085GetTemperature(...) must be called first.
// Value returned will be pressure in units of Pa.
long bmp085GetPressure(unsigned long up)
  long x1, x2, x3, b3, b6, p;
  unsigned long b4, b7;
  b6 = b5 - 4000;
  // Calculate B3
  x1 = (b2 * (b6 * b6) >> 12) >> 11;
  x2 = (ac2 * b6) >> 11;
  x3 = x1 + x2;
  b3 = (((((long)ac1) * 4 + x3) << OSS) + 2) >> 2;
  // Calculate B4
  x1 = (ac3 * b6) >> 13;
  x2 = (b1 * ((b6 * b6) >> 12)) >> 16;
  x3 = ((x1 + x2) + 2) >> 2;
  b4 = (ac4 * (unsigned long)(x3 + 32768)) >> 15;
  b7 = ((unsigned long)(up - b3) * (50000 >> OSS));
  if (b7 < 0x80000000)
    p = (b7 << 1) / b4;
    p = (b7 / b4) << 1;
  x1 = (p >> 8) * (p >> 8);
  x1 = (x1 * 3038) >> 16;
  x2 = (-7357 * p) >> 16;
  p += (x1 + x2 + 3791) >> 4;
  return p;
// Calculate temperature given ut.
// Value returned will be in units of 0.1 deg C
short bmp085GetTemperature(unsigned int ut)
  long x1, x2;
  x1 = (((long)ut - (long)ac6) * (long)ac5) >> 15;
  x2 = ((long)mc << 11) / (x1 + md);
  b5 = x1 + x2;
  return ((b5 + 8) >> 4);
// Read the uncompensated pressure value
unsigned long bmp085ReadUP()
  unsigned char msb, lsb, xlsb;
  unsigned long up = 0;
  // Write 0x34+(OSS<<6) into register 0xF4
  // Request a pressure reading w/ oversampling setting
  Wire.beginTransmission(BMP085_ADDRESS);
  Wire.write(0xF4);
  Wire.write(0x4 + (OSS << 6));
  Wire.endTransmission();
  // Wait for conversion, delay time dependent on OSS
  // delay(2 + (3 << OSS));
  Kernel.Tm_WakeupAfter( 2 + (3 << OSS) );
  // Read register 0xF6 (MSB), 0xF7 (LSB), and 0xF8 (XLSB)
  Wire.write(0xF6);
  Wire.requestFrom(BMP085_ADDRESS, 3);
  // Wait for data to become available
  while (Wire.available() < 3)
  msb = Wire.read();
  lsb = Wire.read();
  xlsb = Wire.read();
  up = (((unsigned long) msb << 16) | ((unsigned long) lsb << 8) | (unsigned long) xlsb) >> (8 - OSS);
  return up;
// Read the uncompensated temperature value
unsigned int bmp085ReadUT()
  unsigned int ut;
  // Write 0x2E into Register 0xF4
  // This requests a temperature reading
  Wire.write(0xF4);
  Wire.write(0x2E);
  // Wait at least 4.5ms
  Kernel.Tm_WakeupAfter( 5 );
  // delay(5);
  // Read two bytes from registers 0xF6 and 0xF7
  ut = bmp085ReadInt(0xF6);
  return ut;
// Stores all of the bmp085's calibration values into global variables
// Calibration values are required to calculate temp and pressure
// This function should be called at the beginning of the program
void bmp085Calibration()
  ac1 = bmp085ReadInt(0xAA);
  ac2 = bmp085ReadInt(0xAC);
  ac3 = bmp085ReadInt(0xAE);
  ac4 = bmp085ReadInt(0xB0);
  ac5 = bmp085ReadInt(0xB2);
  ac6 = bmp085ReadInt(0xB4);
  b1 = bmp085ReadInt(0xB6);
  b2 = bmp085ReadInt(0xB8);
  mb = bmp085ReadInt(0xBA);
  mc = bmp085ReadInt(0xBC);
  md = bmp085ReadInt(0xBE);
// Read 2 bytes from the BMP085
// First byte will be from 'address'
// Second byte will be from 'address'+1
int bmp085ReadInt(unsigned char address)
  unsigned char msb, lsb;
  Wire.write(address);
  Wire.requestFrom(BMP085_ADDRESS, 2);
  while (Wire.available() < 2);
  msb = Wire.read();
  lsb = Wire.read();
  return (int) msb << 8 | lsb;
// Read 1 byte from the BMP085 at 'address'
char bmp085Read(unsigned char address)
  unsigned char data;
  Wire.requestFrom(BMP085_ADDRESS, 1);
  while (!Wire.available())
  return Wire.read();
void fCheck_Pressure()
  Errno_t error;
  // TimerId_t TmId;
  String sMsgToSend;
  sMsgToSend.reserve( StringBufferSize );
  short bmp_temperature;
  long bmp_pressure;
  // float bmp_altitude;
  //Serial.println( "do fCheck_Pressure" );
  //Serial.flush();
  while (1)
    error = Kernel.Tm_WakeupAfter( BMP_Interval );   // Wake up after ... seconds
    if (error != E_SUCCESS)
      Serial.print(F(" WakeupAfter(): Tm_WakeupAfter() Failure! - returned "));
      Serial.print((unsigned)error);
      Serial.flush();
    if ( digitalReadDirect( MWM_PINin ) == 0 )
      sMsgToSend = "Pa ";
      // Serial.println( "do fCheck_Pressure3" );
      // Serial.flush();
      bmp_temperature = bmp085GetTemperature(bmp085ReadUT());
      bmp_pressure = bmp085GetPressure(bmp085ReadUP());
      // sMsgToSend.concat( String(bmp_temperature) + sSeperator );
      sMsgToSend.concat( String(bmp_pressure) + sSeperator );
      // sMsgToSend.concat( String(bmp_altitude) + sSeperator );
      // Serial.println( sMsgToSend );
      // Serial.flush();
      sMsgToSend = "";
  //  // bTask2Started = false;
void fCheck_TH()
  // TimerId_t TmId1;
  String sMsgToSend;
  byte temperature = 0;
  byte humidity = 0;
  String sTH = "TH ";
  while (1)
    Kernel.Tm_WakeupAfter( iDHT_Interval );   // Wake up after ... seconds
      dht11.read(&temperature, &humidity, NULL);
      sMsgToSend = sTH;
      sMsgToSend.concat( String(temperature) + sSeperator + String(humidity) );
      // Serial.flush();
      sMsgToSend = "";
  } // while (1)
void fDO_bRcveDone()
  String sAspectCng = "AspectCng";
  String s_gX = "gX";
  String s_gY = "gY";
  Event_t  eventoutB;
  while (1)
    Kernel.Ev_Receive(EVENT_B, uMT_ANY, &eventoutB);
    digitalWriteDirect( 40, HIGH );
    sPi.replace( "/", " " );
    // sPi.trim();
    // Serial.println(sPi + " bRcveDone" );
    // Serial.flush();
    if (sPi.substring(0, 9) == sAspectCng)
      // Serial.println(sPi + " rcvd" );
      sA = sPi.substring(9);
      Kernel.Ev_Send(iEvtID_E, EVENT_E);
      // Serial.println("AspectString " + sA );
      // Serial.flush();
    // Serial.println( sPi.substring(0, 2) );
    if ( sPi.substring(0, 2) == s_gX )
      // Serial.println(sPi);
      // Serial.flush();
      // stop lidar if lidar has token do not wait for freed token skip torque attempt
      if ( Kernel.Sm_Claim(SEM_ID_03, uMT_NOWAIT) != E_WOULD_BLOCK )
        iX_HowMuch = sPi.substring(3).toInt();
        Kernel.Ev_Send(iEvtID_C, EVENT_C);
    if ( sPi.substring(0, 2) == s_gY )
      // Serial.flush();
        iY_HowMuch = sPi.substring(3).toInt();
        Kernel.Ev_Send(iEvtID_D, EVENT_D);
    sPi = "";
    digitalWriteDirect( 40, LOW );
void fReadSerial()
  Event_t  eventoutA;
  char OneChar;
  while (1)
    // Event_t  eventoutA;
    Kernel.Ev_Receive(EVENT_A, uMT_ANY, &eventoutA);
    while ( stream2Ptr->available() )
      OneChar = stream2Ptr->read();
      if ( (OneChar != '\n') )
        //Serial.println(sPi);
        sPi.concat( OneChar );
        // Serial.println(sPi + " char" );
        // Serial.flush();
      } // if ( (OneChar != '\n') )
        Kernel.Ev_Send(iEvtID_B, EVENT_B);  // trigger fDO_bRcveDone
        // bRcveDone = true;
        // Serial.println( "bRcveDone set true" );
        Serial.flush();
      } // if ( (chrOne != '\n') ) else
    } // while ( Serial2.available() )
    Kernel.Sm_Release( SEM_ID_04); // release serial avaible trigger in loop
  } //  while (1)
  1000 u sec to 2000 u sec limit = 90 degrees of travel +/-45 deg
  1K = 45 to 2K = 135
void fTweakServoX()
  Event_t  eventoutC;
  while (1)
    Kernel.Ev_Receive(EVENT_C, uMT_ANY, &eventoutC);
    X_Axis.writeMicroseconds( iX_HowMuch );
void fTweakServoY()
  Event_t  eventoutD;
  while (1)
    Kernel.Ev_Receive(EVENT_D, uMT_ANY, &eventoutD);
    // Serial.println( "iY_HowMuch = " + String(iY_HowMuch) );
    Y_Axis.writeMicroseconds( iY_HowMuch );
//  send data to RPi
void fSendOut_SEMAPHORE()
  Event_t  eventoutF;
  while (1)
    Kernel.Ev_Receive(EVENT_F, uMT_ANY, &eventoutF);
    // Serial.println("fSendOut_SEMAPHORE 0 " + sMessageToSend );
    // Serial1.flush();
    if ( sMessageToSend.length() >= 2 )
      // Serial.println("fSendOut_SEMAPHORE 1 " + sMessageToSend );
      // Serial.flush();
      stream2Ptr->println( sMessageToSend );
      digitalWrite(byteUnoDataReady, HIGH);//TRIGGER RPi3 to read data
      // delay( .05 );
      Kernel.Tm_WakeupAfter( 50 );
      // Serial.println( sMessageToSend.length() );
      // Serial.println("fSendOut_SEMAPHORE " + sMessageToSend );
      // Serial.flush();
      digitalWrite(byteUnoDataReady, LOW);//reset
      sMessageToSend = "";
void fLIDAR_ServoAspectChange()
  char fltBuff[32];
  String sAspectComplete = "AspectComplete";
  Event_t  eventoutE;
  String sMsgToSend;
  while (1)
    Kernel.Ev_Receive(EVENT_E, uMT_ANY, &eventoutE);
    Kernel.Sm_Claim(SEM_ID_02, uMT_WAIT); // // claim a single SEMAPHORE token.
    if ( sA.length() < 8 )
      // bBlankLIDAR = true;
      sA.toCharArray(fltBuff, sizeof(fltBuff));
      float fltAspect = atof(fltBuff);
      if (fltAspect > 900.00f)
        // Serial.println("AspectString " + String(sA));
        // Serial.flush();
        ServoLIDAR.writeMicroseconds(fltAspect);
      //delay(20);
      // Serial.println( "AspectComplete " + sA );
      // Serial.flush();
      Serial.println("AspectString reject " + String(sA));
    // Serial.println( "fLIDAR_ServoAspectChange " + sMessageToSend );
    // Serial.flush();
    sMsgToSend = sAspectComplete;
    // bBlankLIDAR = false;
void fCheckInputVoltage()
  String sMsgToSend;
  String s_Volts = "VOLT ";
  while (1)
    Kernel.Tm_WakeupAfter( iDoVolts_Interval );   // Wake up after ... seconds
    // Serial.println( "dovolt awake1" );
    // Serial.flush();
      sMsgToSend = s_Volts;
      sMsgToSend.concat(String(analogRead(A0)));
      // Serial.println( "fCheckInputVoltage" + sMsgToSend );
      // Serial.flush();
      sMsgToSend = "";
      // Kernel.Sm_Release(SEM_ID_02);
  1K = 45 to 2K = 135
void fTweakServoX()
  Event_t  eventoutC;
  while (1)
void fTweakServoY()
  Event_t  eventoutD;
  while (1)
//  send data to RPi
  Event_t  eventoutF;
  while (1)
    // Serial1.flush();
      // Serial.flush();
      // delay( .05 );
      // Serial.flush();
  char fltBuff[32];
  Event_t  eventoutE;
  String sMsgToSend;
  while (1)
        // Serial.flush();
      //delay(20);
      // Serial.flush();
    // Serial.flush();
  String sMsgToSend;
  while (1)
    // Serial.flush();
      // Serial.flush();
      sMsgToSend = "";
Thanks idahowalker,
I tried your suggestions but they did not work for me. I have more problems than that. I'm going to send down a string that is called "DONE" and when I get it I'm going to allow the code below the switch statement to continue. That should work because after I execute the switch statement below the inner loop I can disable it.
Thanks,
pamam
