While Loop Not Breaking
I am trying to use the following while loop to latch a pump on when a Hi Limit is activated, when the low limit is reached the while loop should exit and the pump turn off.
When testing:
The pump comes on when Hi Limit active
The pump remains on when Hi Limit deactivated
However when the Lo Limit is deactivated the pump stays on
What have a missed?
  if (STATE_FLOAT_HI_LIMIT == HIGH)
    while (STATE_FLOAT_LO_LIMIT == HIGH) // Latch - Pump run until Lo Limit deactivated
      digitalWrite(PIN_PUMP_1_ACTIVE, HIGH); //Duty Pump On
      if (STATE_FLOAT_LO_LIMIT == LOW)
  else (STATE_FLOAT_HI_LIMIT == LOW && STATE_FLOAT_LO_LIMIT == LOW);
    digitalWrite(PIN_PUMP_1_ACTIVE, LOW); //Duty Pump Off
(deleted)
seems obvious now its pointed out i was under the impression the value would update but thank you i have tested and it now works
      STATE_FLOAT_LO_LIMIT = digitalRead(PIN_FLOAT_LO_LIMIT);
Why not keep it simpler and just go:
    if (digitalRead(PIN_FLOAT_LO_LIMIT))
MarkT:
im not following can you expand on this
