while loop question
while (numChar--) {
buffer[index++] = Serial.read();
The code above is a snippet from the ASKManual Version 5.
The author explains it as such:
"The condition it is checking is simply numChar, so in
other words it is checking that the value stored in the
integer numChar is not zero"
I do not see any where that the condition of "not zero" is being checked. I see only the decrement. Shouldn't there be something like !=0. ??
I am a newbie so sorry if this is a dumb question
The value of numchar is tested for true/false before the (post-)decrement takes place. It isn't necessary to assign the value of an expression in order to examine it.
In C or C++
True is any Non-Zero Value like .... -3,-2,-1,1,2,3....
False is Zero
syntax: while( expression)
statement;
or
while( expression)
statements
expression can be evalueted as Zero or Non-Zero
if the expression is Non-Zero then statement or statements will be executed.
i.e. while(numChar--) can be treated as
while(numChar !=0)
numChar--;
thanks all, this makes sense now
