while loop
int var =0;
int inputPin =10;
pinMode(inputPin, INPUT);
  while(var > 200);
    Serial.println(var);
    var++;
can any one tell me what syntax i would use insted of the (var>20 )
if i wanted an 5v input from pin 10 to stop the loop
thanks
Try
while(!digitalRead(10)){
  // do something until pin 10 goes HIGH
thanks
int var =0;
int inputPin =10;
  while(var > 200);  <<<<<<<<<<<<<<<<<<< the ; is wrong   remove it
    var++;
    var++;
Since var starts at 0, the while block will not be executed until loop has been executed 200 times. At that point, the while loop becomes an endless loop, and stops the Arduino from printing to the serial port. Perhaps that IS what OP wanted.
No, I doubt it is that subtle
