Hello,
I have written a simple program to initialize an SD card and test if a file name is present. The file name has a numerical increment value. The program should increment this value until the file it is looking for does not exist.
The console data is as follows:
Initializing SD card...card initialized.
data01.TXT already exists
incremented file name is now data02.TXT
The string filename has changed to data02.txt yet it becomes the old value of data01.txt when the loop repeats.
What can I do to fix this?
Thank you.
[code]
#include <SPI.h>
#include <SD.h>
const int chipSelect = 10; //using pin 10 as chip select
String filenum = "01";
String filename = "data" + filenum + ".TXT"; //first file name is data01.TXT
while (!Serial) {
; // wait for serial port to connect
Serial.print("Initializing SD card...");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
while (1);
Serial.println("card initialized.");
//Note: SD library only recognizeds file names 8.3 !!
while (SD.exists(filename)) {
Serial.print(filename); Serial.println(" already exists");
int file_increment = filenum.toInt(); //change file increment to an integer
++file_increment; //add one to the file increment
String filenum = "0" + String(file_increment); //create a new increment with leading 0
String filename = "data" + filenum + ".TXT"; //creates the new file name incremented by 1
Serial.print("incremented file name is now "); Serial.println(filename); //prints new file
//should now check for the incremented file name and repeat until an non-existent file name occurs
Serial.print("next available file name "); Serial.print(filename);
[/code]
