Hello,
There is a small part of my code that im stuck with. i am using a while statement to execute a command to a piece of hardware (mp3 trigger)
To trigger the mp3 track it seems the trigger likes a HIGH followed by LOW signal ie the track is played on the signal changing back from HIGH to LOW. the trouble i am having is that if i send HIGH, delay(x) then LOW delay(x) the mp3 track is either, if the delay is very short (100-500) constantly restarted at the end of the delay, or if the delay is too long (500+) the response to the next if statement is far too slow.
Is there a simple way of sending a brief HIGH then a LOW once only without it looping? Any suggestions are very much appreciated
this is the code:
while (digitalRead(switchPin)==LOW) {
digitalWrite(tracktwo, HIGH); // trigger track two - ringtone
delay (300);
digitalWrite(tracktwo, LOW);
delay(1200);
if it helps this is the rest of the code to put it in context
void ring (){
if (hookState==HIGH) {
ringAction.setInterval(30*1000); //check again in 30 sec because the phone was already lifted
else { // start ringing
Serial.println("2 hookval LOW. start ringing: tracktwo HIGH, relay LOW - START VOID RING LOOP ");
digitalWrite(relayswitch, LOW); //relay switch is LOW - main speaker
delay (300);
delay(1200);
//TODO add a timeout to this endless loop, calls until pickup
//phone is ringing and is picked up
Serial.println("3 hookval - trackthree HIGH, relayswitch HIGH - PHONE PICKED UP PLAYING MESSAGE ");
digitalWrite(relayswitch, HIGH); //relay switch is high - plays through earpiece
digitalWrite(trackthree, HIGH); // play track 3 answer message
digitalWrite(trackthree, LOW);
while (digitalRead(switchPin)==HIGH) {/*wait*/
Serial.print("4 hookval- trackstop HIGH, relayswitch LOW - PHONE PUT DOWN STOP MESSAGE PLAYING ");
digitalWrite(trackstop, HIGH);
delay(400);
digitalWrite(trackstop, LOW);
Serial.println("END OF VOID RING LOOP ");
ringAction.setInterval(INTERVAL); //schedule next call
