Hello, I have a program that runs in the void loop. I want to halt the loop whilst a GPIO input remains HIGH.
int inputValue = digitalRead(inputPin);
digitalWrite(outputPin,inputValue);
while (inputValue == LOW) {
// Wait for the input pin to go low
delay(500); // Delay before the next loop runs.
The above does not stop the program flow running whilst the IO Port is HIGH. It just continues as if it's not checking.
I have tested the Input port state by outputing its state to another output port and that works fine. But the while statement fails. I am confused.
I'm confused. If inputValue is HIGH, the while condition is false and the loop won't be executed. If inputValue is LOW, the while loop will be entered and executed forever, as there's nothing inside the loop to change inputValue.
The inputValue never changes inside the while-loop; so once you are in there, it will stay in there. You will need to read the input pin inside the while-loop and assign the value of the read to inputValue.
Note that your code is blocking code; so e.g. blinking a LED while waiting for the button is tricky.
while (inputValue == HIGH) {
Assuming HIGH is active for both the button and LED, the interaction of the delay() and while() would make the LED turn off 500ms after you release the button, but turn on 0-500ms after you press the button.
The original code would (randomly) hang in the infinite loop. Randomly activated depending how long you pushed the button and where in the delay(500) cycle you pushed it.
Both behaviors don't seem like behaviors anyone would intend to expect.
Many times I use a line like Serial.print(".") to diagnose unexpected behavior of loops and ifs, etc... It can show you if things are happening as you expect, and it's easy duplicate with different letters to test other features.
const byte inputPin = 2;
const byte outputPin = 13;
pinMode(inputPin, INPUT_PULLUP);
pinMode(outputPin, OUTPUT);
void loop(void) {
digitalWrite(outputPin, inputValue);
Serial.print(".");
Serial.print("d");
