Hi!
I have just bought a small OLED (link here) that has 6 pins:
GND
VCC
SCL
SDA
RST
D/C
I'm searching everywhere and can not find any good tutorial on how to connect it and what libraries to use.
I have searched the Adafruit tutorial, but all of them are different... 4 pins, 8 pins, same amount of pins but different usages...
Can anyone point me to the right direction?
Thanks!
Ok, I found the solution, quite easy, but It took me about 3 hours to find the solution.
for future reference:
library: Adafruit_SSD1306
pin connection:
GND = ground
VCC = 3.3 or 5v
SCL = OLED_CLK
SDA = OLED_MOSI
RST = OLED_RESET
D/C = OLED_DC
for some reason "OLED_CS" does not exist on the board, and therefor does not need to be plugged anywhere, but still needs to be in the code... use any arduino pin that is for in use.
