White screen on 3.5 inch TFT (ili9327) and touch problem on 2.8 inch TFT (ILI932
Hi everyone,
I received a month ago, my two new TFT touch screen but I can't make it work with arduino uno r3.
First one:
Front / Rear
3,6 TFT LCD Color Touch Screen for Uno R3
400x240 pixels
Controller ILI9327
Library: GitHub - dgolda/UTFT: Modified UTFT library working with ILI9327 8-bit for example 3.5" TFT LCD from mcufriend.com
Source: For the code I use the example in arduino AVR and the UTFT_Demo_400x200.
UTFT myGLCD(ILI9327_8,A2,A1,A3,A4);
Problem: The screen still White
Using AdaTFTLCD Librarie I got this in Serial.
tft.reset();
delay(5000);
uint16_t identifier = tft.readID();
Serial Message:
TFT size is 240x320
Unknown LCD driver chip: 4444
Second one:
Front / Rear
Display Tft 2.8 Touch Shield for Arduino Uno
240x320 pixels
Controller ILI9325DS
DataSheet: here
Library: UTFT - Rinky-Dink Electronics
Problem: The display works fine, but does not recognize any touch command, I've tried with UTouch and TouchScreen libraries
Source: UTFT myGLCD(ITDB28,19,18,17,16);
UTouch myTouch(15,10,14,8,9);
I also have the Arduino Due, but I don't found the correct pins sequence.
So if somebody could tell me what I'm doing wrong, it would be nice :slight_smile:
Thank you for your help.
