I recently bought this ILI9341 board from AliExpress. In the reviews nobody seemed to have a problem with it.
However, when I try the Adafruit ILI9341 library, I only get a white screen. I tried also putting the data pins through 1K resistors, but it did not change anything.
Most interesting part is that I tested it with Adarfuit ST7735 (just for laughs) library, it seemed to work better. It did not 100%, but some artefacts could be seen from the graphics test. More than a white screen at least. This led me to think that theoretically the display should work, just a problem with the library.
UNO +5V to display pin 1 (VCC)
UNO +5V through a 56 Ohm resistor to display pin 8 (LED)
Typical connections are:
UNO 0V (GND) to display pin 2 (GND)
UNO digital pin 7 through a 1K2 resistor to display pin 4 (RESET), add a 1K8 resistor from display pin 4 to GND
UNO digital pin 8 through a 1K2 resistor to display pin 5 (DC/RS), add a 1K8 resistor from display pin 5 to GND
UNO digital pin 9 through a 1K2 resistor to display pin 3 (CS), add a 1K8 resistor from display pin 3 to GND
UNO digital pin 11 through a 1K2 resistor to display pin 6 (SDI/MOSI), add a 1K8 resistor from display pin 6 to GND
UNO digital pin 13 through a 1K2 resistor to display pin 7 (SCK), add a 1K8 resistor from display pin 7 to GND
It is important to include the 1K8 resistors to GND with this 2.2" display as otherwise it will not work. The 1K2 and 1K8 resistors are a "potential divider", acting as a logic level shifter so that the logic level at the display is reduced from 5V to around 3V. Pin 9 of the display does not need to be connected up.
Thanks a lot, it's working now! However, I still cannot manage the SD card to work for bitmap image displaying. I tried to connect the MISO to UNO pin 12 and SD_CS to UNO pin 4, but it still says "Initializing filesystem...SD begin() failed" in the serial monitor.
