Who can Help Me Solving Input Problem
who can help me solve my problem i want do a bluetooth door lock with arduino
but i want to ask user choose the way to go if user prompt 1 go for ask for password
if user prompt 2 go for change password
but when i keyin 1 and go for the ask password it wont getting any value
how who can help me pls
#include <SPI.h>
#include "Adafruit_BLE_UART.h"
#define LOCK_PIN 6
#define RED_LED_PIN 7
#define GREEN_LED_PIN 8
#define ADAFRUITBLE_REQ 10
#define ADAFRUITBLE_RDY 2
#define ADAFRUITBLE_RST 9
long secret = 12345;
long code;
long pass;
long openTime = 0;
boolean test = true;
boolean testt = false;
// Status from the Bluefruit LE driver
int lastStatus = ACI_EVT_DISCONNECTED;
Adafruit_BLE_UART BTLEserial = Adafruit_BLE_UART(ADAFRUITBLE_REQ, ADAFRUITBLE_RDY, ADAFRUITBLE_RST);
  Serial.println(F("BLE Safe - Adafruit Bluefruit Low Energy Edition"));
  BTLEserial.begin();
  pinMode(LOCK_PIN, OUTPUT);
  pinMode(RED_LED_PIN, OUTPUT);
  pinMode(GREEN_LED_PIN, OUTPUT);
  digitalWrite(LOCK_PIN, LOW);
  digitalWrite(RED_LED_PIN, LOW);
  digitalWrite(GREEN_LED_PIN, LOW);
  BTLEserial.println("Welcome");
  // Tell the nRF8001 to do whatever it should be working on
  BTLEserial.pollACI();
  int status = BTLEserial.getState();
  if (status != lastStatus) {
    if (status == ACI_EVT_DEVICE_STARTED) {
      Serial.println(F("* Advertising Started"));
    else if (status == ACI_EVT_CONNECTED) {
      Serial.println(F("* Connected!"));
    else if (status == ACI_EVT_DISCONNECTED) {
      Serial.println(F("* Disconnected or advertising timed out."));
    // save for next loop
    lastStatus = status;
    // see if there's any data from bluetooth
    if (BTLEserial.available()) {
      Serial.print("* ");
      Serial.print(BTLEserial.available());
      Serial.println(F(" bytes available from BTLE"));
    // keeping u + code for compatibility with the serial api
   int var = BTLEserial.parseInt();
   switch (var) {
    case 1:
      openLock();
    case 2:
      changePass();
  // close lock and reset lights after x seconds
  if (openTime && millis() - openTime > 4000) {
    resetLock();
void openLock()
  BTLEserial.println("What is your password");
  int code = BTLEserial.parseInt();
  Serial.println(String(code));
  if (code == secret)
    openTime = millis();  // set even if bad code so we can reset the lights
    // open the lock
    Serial.println("Code matches, opening lock");
    digitalWrite(GREEN_LED_PIN, HIGH);
    digitalWrite(LOCK_PIN, HIGH); // open the lock
    BTLEserial.println("unlocked");
    // bad code, don't open
    Serial.println("Invalid code " + code);
    digitalWrite(RED_LED_PIN, HIGH);
    BTLEserial.println("invalid code");
void changePass() {
    BTLEserial.println("Passcode");
// closes the lock and resets the lights
void resetLock() {
  // reset the lights
  digitalWrite(LOCK_PIN, LOW); // close the lock
  BTLEserial.println("locked");
  openTime = 0;
You are repeating yourself
http://forum.arduino.cc/index.php?topic=281802.msg1979424#msg1979424
