Who can me explain some lines of code...
Hi to all of you,
i have some questions about some lines, hopefully some people can help me. i have these lines
void JoystickEvents::OnGamePadChanged(const GamePadEventData *evt)
	Serial.print("X: ");
	PrintHex<uint8_t>(evt->X);
it from the usb host 2 library/usbhidjoystick.h. i cant get the structur/logic behind some stuff of these short lines.My questions are:
  1. What does the “::” means between “JoystickEvents::OnGamePadChanged”? is it the “method in a class”?
  2. What does “*evt” at “const GamePadEventData evt" means (is it like a tag to get the “Part of X” in the uint8_t)? What does the "” means?
  3. what does “->” means in “PrintHex<uint8_t>(evt->X)”?
Especially the “*” and the “->” are weird for me and i didnt find anything in the documentary…
Thanks for your help
b.
http://www.cplusplus.com/
GamePadEventData is an object, most probably a struct/class.
//This is most probably not the structure, but will explain my point.
struct GamePadEventData{
  int X;
  int Y;
In the function the * denotes a pointer type:
Here the meaning is ( RTL ): evt is a pointer to a GamePadEventData ( which is constant ). The '::' is a scope operator which in this case is showing that 'OnGamePadChanged' is a member of the object 'JoystickEvents'.
This would be passing by reference:
void JoystickEvents::OnGamePadChanged(const GamePadEventData &evt)
Or by value:
void JoystickEvents::OnGamePadChanged(const GamePadEventData evt)
So, as you are passing a pointer, we cannot access X, Y directly. You could dereference the pointer to an object then access:
GamePadEventData &c_Data = *evt;
Serial.print( c_Data.X );
But in the case of your code, the dereference is done in the pointer to member operator: '->'. So you can skip the dereference yourself.
Serial.print( evt->X );
A good C++ tutorial will help with these concepts.
Thanks a guys! This helped me a lot to understand the structure. For a newbie all the different signs and letters are a bit confusing…but hope to get the basics soon.
But before one more little question:
When i wann control something like a stepper with the value x and i have a stepper library like the stepper.h so is it right to write it like:
stepper.setSpeed(<uint8_t>(evt->X));
or is
stepper.setSpeed(evt->X);
enough?
No, your code using ‘<>’ is a template function, it has its own meaning:
If evt->X is a 16 bit value but you need to pass in an 8 bit value, you can cast using ‘()’
stepper.moveTo( ( uint8_t ) evt->X );
However the top 8 bits are chopped off so high values are no use.
It should be fine to just use:
stepper.moveTo( evt->X );
Big thanks to you,pYro!
so i understand some more ;-) unfortunately i cant get the stepper-control combined with the usb-hid-joystick-control.
i think i will close this thread and do a new one for my next questions.
