I used arduino leonardo as arduino uno can't be recognized in the computer as keyboard or mouse i use 2 analog joystick code will be provided below:
#include <Keyboard.h> // Use built-in Keyboard library
#include <HID_Buttons.h> // Must import AFTER Keyboard.h
#include <Mouse.h> // For controller2 which is gonna be for mouse
const uint8_t Pin_XAxis = A0; // Pin for joy horizontal axis
const uint8_t Pin_YAxis = A1; // Pin for joy vertical axis
const int JoyCenter = 1023 / 2; // max value for 10-bit ADC / 2
const int JoyDeadzone = 50; // +/- area around the center to ignore
int horzPin = A2; // Analog output of horizontal joystick pin
int vertPin = A3; // Analog output of vertical joystick pin
int selPin = 9; // select button pin of joystick
int vertZero, horzZero; // Stores the initial value of each axis, usually around 512
int vertValue, horzValue;//Stores current analog output of each axis
const int sensitivity = 215; // Higher sensitivity value = slower mouse, should be <= about 500
int mouseClickFlag = 0;
//int invertMouse = 1; //Invert joystick based on orientation
int invertMouse = -1; //Noninverted joystick based on orientation
//Error Occurs after some time of use please change if joystick doesn't work!
KeyboardButton moveForward('A');
KeyboardButton moveLeft('S');
KeyboardButton moveBackward('D');
KeyboardButton moveRight('W');
Keyboard.begin();
pinMode(horzPin, INPUT); // Set both analog pins as inputs
pinMode(vertPin, INPUT);
pinMode(selPin, INPUT); // set button select pin as input
digitalWrite(selPin, HIGH); // Pull button select pin high
delay(1000); // short delay to let outputs settle
vertZero = analogRead(vertPin); // get the initial values
horzZero = analogRead(horzPin); // Joystick should be in neutral position when reading these
Mouse.begin(); //Init mouse emulation
int x = analogRead(Pin_XAxis); // Read X axis
int y = analogRead(Pin_YAxis); // Read Y axis
moveLeft.set(x < JoyCenter - JoyDeadzone);
moveRight.set(x > JoyCenter + JoyDeadzone);
moveForward.set(y < JoyCenter - JoyDeadzone);
moveBackward.set(y > JoyCenter + JoyDeadzone);
vertValue = analogRead(vertPin) - vertZero; // read vertical offset
horzValue = analogRead(horzPin) - horzZero; // read horizontal offset
if (vertValue != 0)
Mouse.move(0, (invertMouse * (horzValue / sensitivity)), 0); // move mouse on y axis
if (horzValue != 0)
Mouse.move((invertMouse * (vertValue / sensitivity)), 0, 0); // move mouse on x axis
if ((digitalRead(selPin) == 0) && (!mouseClickFlag)) // if the joystick button is pressed
mouseClickFlag = 1;
Mouse.press(MOUSE_LEFT); // click the left button down
Serial.println("Joystick button is clicked");
else if ((digitalRead(selPin)) && (mouseClickFlag)) // if the joystick button is not pressed
mouseClickFlag = 0;
Mouse.release(MOUSE_LEFT); // release the left button
Your welcome if i helped you create a game controller but: A1 to 1st joystick Pin x, A2 to 1st joystick y, A3 to 2st joystick x, A4 to 2st joystick y
