Why a delay after digitalWrite(PUL,LOW) during stepper motor control?
When I comment out the delay, i.e.:
digitalWrite(PUL,HIGH);
delayMicroseconds(374);
digitalWrite(PUL,LOW);
//delayMicroseconds(374);// Is the needed?, works fine without
The motor works just fine without it. (speeds up of course, but if I double the Write delay it goes back to its orginal speed as expected).
Is it really needed?
Thanks for your help.
Driver: DFRobot TB6600, TB6600 Arduino Stepper Motor Driver - DFRobot
Motor: https://www.omc-stepperonline.com/download/17HS15-1684S-HG100.pdf
4 wire bipolar
maxmach:
Driver: DFRobot TB6600, https://www.dfrobot.com/product-1547.html
4 wire bipolar
You have probably studied the data sheets longer than I did. Nowhere do I see the time parameter for the "pulse". So, I guess you may time it anyway you like, even with no program delay at all.
Paul
The digitalWrite() command is slow and a pair of them gives a pulse that is long enough for most stepper drivers. Have a look at this Simple Stepper Code. I hope the variable names are self-explanatory.
If you need more performance there is a digitalWriteFast library. With it you would need to create a interval for the pulse.
...R
Stepper Motor Basics
AccelStepper library
