Why am I getting strange oriental characters using print.ln() function
Can anyone explain this?
Uploaded with ImageShack.us
#include <LiquidCrystal.h>
const int timerstart = 8;
const int timerstop = 9;
int seconds = 0;
int timerstart1 = 0;
int timerstop1 = 0;
int output = 13;
int setseconds = 10;
int on = 0;
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  lcd.begin(16, 2);
  pinMode(timerstart, INPUT);
  pinMode(timerstop, INPUT);
  pinMode(output, OUTPUT);
  seconds = setseconds;
  timerstart1 = digitalRead(timerstart);
  lcd.setCursor(0, 0);
  lcd.print("Time: ");
  lcd.println(seconds);
 if (timerstart1 == HIGH) {
  on = 1;
if (timerstop1 == HIGH) {
  on = 0;
if (on == 1){
  seconds--;
if (seconds == -1) {
digitalWrite(output, HIGH);
on = 0;
digitalWrite(output, LOW);
You don't want to send and to the display.
(They are both printable characters)
--- bill
In other words ... did you notice that there is no description for an lcd.println() function ?
Don
I see what your saying, so do I need to change what function I am using or define and so that they do not appear on the screen. I am new to Arduino so could someone give an example code for what I need to do please?
Kind Regards
use lcd.print instead of lcd.println. That's all.
I see what your saying, so do I need to change what function I am using ...
Yes. As GUNN has explained already.
... or define and so that they do not appear on the screen.
There's no way to do that. The definitions are engraved in the computer equivalent of stone, in Read only Memory.
You have to understand that these character LCDs are not designed to replace CRT displays. They are designed to display short messages on printers, toasters, etc. To put stuff on a new line you have to use the 'set cursor' function.
Don
You have to control display cursor yourself if you want a new line with lcd.setCursor(x,y)
If you are already on the bottom line and do another new line, write the bottom line on the top line, and new line on the bottom line to make the message scroll.
You need to have a buffer as large as the size of the display and use it to do the new lines and scroll.
You need more effort to do what you want: scrolling and new line. On the other hand, I sell a serial LCD that will do this for you plus a bunch of other stuff. Here is the link.
Thankyou guys!
I guess I totally misunderstood the LCD.Println() function completely! :*
Liudr, did you get my message about using the rotary shaft encoder (phi_interface) to control variables ( i cant seem to do it) and to change the pin designation for channel A and B (changing the numbers in the define part of the code doesnt seem to work)
Kind Regards
GUNN:
Thankyou guys!
Kind Regards
Yes, I did. Must have read it and somehow forgot to reply :cold_sweat:
You can use this rotary encoder for the purpose. Why not starting a new thread so it's easy to post and read code. Just PM me the thread.
