int LedPin = 8;
pinMode(LedPin, OUTPUT);
digitalWrite(LedPin, HİGH);
digitalWrite(LedPin, LOW);
why am i getting this error ?
sketch_oct09a:11:25: error: stray '\304' in program
sketch_oct09a:11:26: error: stray '\260' in program
C:\Users\KASA\AppData\Local\Temp\arduino_modified_sketch_804120\sketch_oct09a.ino: In function 'void loop()':
sketch_oct09a:11:24: error: 'H' was not declared in this scope
C:\Users\KASA\AppData\Local\Temp\arduino_modified_sketch_804120\sketch_oct09a.ino:11:24: note: suggested alternative: 'ZH'
ZH
sketch_oct09a:14:14: error: expected '}' at end of input
exit status 1
Because you cut and pasted the code (which is incomplete) from a website?
Please remember to use code tags when posting code
Using an external editor?
Why do you think this is a bootloader issue?
Did you type directly into the IDE?
What is the letter after the H in HIGH? It appears to have a dot above a capital I - are you typing with a keyboard using a non-English character set?
Hex dump of your code shows some extra hidden characters:
00000000 76 6f 69 64 20 6c 6f 6f 70 28 29 20 7b 0a 64 69 |void loop() {.di|
00000010 67 69 74 61 6c 57 72 69 74 65 28 4c 65 64 50 69 |gitalWrite(LedPi|
00000020 6e 2c 20 48 c4 b0 47 48 29 3b 0a 64 65 6c 61 79 |n, H..GH);.delay|
00000030 28 31 30 30 30 29 3b 0a 64 69 67 69 74 61 6c 57 |(1000);.digitalW|
00000040 72 69 74 65 28 4c 65 64 50 69 6e 2c 20 4c 4f 57 |rite(LedPin, LOW|
00000050 29 3b 0a 64 65 6c 61 79 28 31 30 30 30 29 3b 0a |);.delay(1000);.|
00000060
error304:
int LedPin = 8;
i didn't see i wrote that thank you
Your post was MOVED to its current location as it is more suitable.
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Hello,
Welcome to the Arduino Forum.
This guide explains how to get the best out of this forum. Please read and follow the instructions below.
Being new here you might think this is having rules for the sake of rules, but that is not the case. If you don’t follow the guidelines all that happens is there is a long exchange of posts while we try to get you to tell us what we need in order to help you, which is frustrating for you and frustrating for us.
The people who try to help with your pro…
system
Closed
April 7, 2022, 11:21pm
12
