/usr/local/bin/arduino-cli compile --fqbn esp8266:esp8266:nodemcuv2:baud=9600,xtal=80,eesz=4M,dbg=Disabled,lvl=None____,ip=lm2f,vt=flash,exception=disabled,wipe=none --build-cache-path /tmp --output-dir /tmp/1096908336/build --build-path /tmp/arduino-build-8457ABA4E994AA8783059BB1CE30F4DE /tmp/1096908336/NodeMcu_dec08a
[info] Sketch uses 426512 bytes (40%) of program storage space. Maximum is 1044464 bytes.
[info] Global variables use 36680 bytes (44%) of dynamic memory, leaving 45240 bytes for local variables. Maximum is 81920 bytes.
Flashing with command:C:/Users/HP/.arduino-create/esp8266/esptool/2.5.0-3-20ed2b9/esptool.exe -vv -cd nodemcu -cb 9600 -cp COM10 -ca 0x00000 -cf C:/Users/HP/AppData/Local/Temp/arduino-create-agent2780520837/NodeMcu_dec08a.bin
esptool v0.4.13-1-gf80ae31 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to nodemcu
setting baudrate from 115200 to 9600
setting port from COM1 to COM10
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
flush start
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
read 0, requested 1
trying to connect
flush start
flush complete
espcomm_send_command: receiving 2 bytes of data
Uploading 430656 bytes from C:/Users/HP/AppData/Local/Temp/arduino-create-agent2780520837/NodeMcu_dec08a.bin to flash at 0x00000000
erasing flash
size: 069240 address: 000000
first_sector_index: 0
total_sector_count: 106
head_sector_count: 16
adjusted_sector_count: 90
erase_size: 05a000
setting serial port timeouts to 15000 ms
writing flash
wrote 992, requested 1072
error: failed sending 1072 bytes
. wrote 992, requested 1044
error: failed sending 1044 bytes
. wrote 1024, requested 1040
error: failed sending 1040 bytes
. wrote 992, requested 1040
. wrote 992, requested 1050
error: failed sending 1050 bytes
. wrote 992, requested 1049
error: failed sending 1049 bytes
. wrote 992, requested 1048
error: failed sending 1048 bytes
. wrote 1024, requested 1065
error: failed sending 1065 bytes
. wrote 992, requested 1072
. wrote 992, requested 1082
error: failed sending 1082 bytes
. wrote 992, requested 1096
error: failed sending 1096 bytes
. wrote 1024, requested 1104
error: failed sending 1104 bytes
. wrote 1024, requested 1071
error: failed sending 1071 bytes
. wrote 992, requested 1056
error: failed sending 1056 bytes
. wrote 1024, requested 1048
. wrote 992, requested 1045
error: failed sending 1045 bytes
. wrote 1024, requested 1045
. wrote 992, requested 1053
error: failed sending 1053 bytes
. wrote 992, requested 1047
error: failed sending 1047 bytes
. wrote 1024, requested 1052
error: failed sending 1052 bytes
. wrote 992, requested 1057
error: failed sending 1057 bytes
. wrote 1024, requested 1053
. wrote 1024, requested 1067
error: failed sending 1067 bytes
. wrote 992, requested 1062
error: failed sending 1062 bytes
. wrote 1024, requested 1054
error: failed sending 1054 bytes
. wrote 1024, requested 1070
error: failed sending 1070 bytes
. wrote 992, requested 1069
error: failed sending 1069 bytes
. wrote 1024, requested 1057
. wrote 992, requested 1054
. wrote 992, requested 1059
error: failed sending 1059 bytes
. wrote 1024, requested 1044
. wrote 1024, requested 1050
. wrote 992, requested 1043
error: failed sending 1043 bytes
. wrote 1024, requested 1047
. wrote 992, requested 1051
error: failed sending 1051 bytes
. wrote 992, requested 1071
. wrote 1024, requested 1073
error: failed sending 1073 bytes
. wrote 1024, requested 1046
error: failed sending 1046 bytes
. wrote 992, requested 1066
error: failed sending 1066 bytes
. wrote 992, requested 1052
. wrote 1024, requested 1063
error: failed sending 1063 bytes
. wrote 992, requested 1058
error: failed sending 1058 bytes
. wrote 992, requested 1061
error: failed sending 1061 bytes
. wrote 1024, requested 1051
. wrote 1024, requested 1049
. wrote 1024, requested 1061
. wrote 1024, requested 1062
. wrote 1024, requested 1056
. wrote 992, requested 1068
error: failed sending 1068 bytes
. wrote 992, requested 1060
error: failed sending 1060 bytes
. wrote 992, requested 1075
error: failed sending 1075 bytes
. [ 19% ]
. wrote 1024, requested 1058
. wrote 992, requested 1063
. wrote 992, requested 1046
. wrote 992, requested 1067
. wrote 992, requested 1055
error: failed sending 1055 bytes
read 0, requested 1
warning: espcomm_send_command: didn't receive command response
warning: espcomm_send_command(FLASH_DOWNLOAD_DATA) failed
warning: espcomm_send_command: wrong direction/command: 0x01 0x03, expected 0x01 0x04
closing bootloader
flush start
flush complete
error: espcomm_upload_mem failed
Executing command: exit status 2
Read the following and follow instructions https://forum.arduino.cc/t/how-to-get-the-best-out-of-this-forum/1111649
Hi @apurva_s45. I'm going to ask you for some additional information that might allow us to determine what is causing this error. Please add a reply here on the forum thread with the answers to the following questions:
Which specific board do you have? It will be useful if you provide a link to the product page from which you purchased the board as we will probably be able to glean technical details from it.
Do you have any external wiring, shields, modules, etc. connected to the board, or is it only the board alone connected to your computer?
The code is being compiled on Arduino iot cloud editor but the issue starts when I start to upload it to my board and I'm using this platform from a month and only frm yesterday I'm facing this issue before this the code was being dumped to the code
Please provide the information I requested.
I am using esp8266 (NodeMcu ver 0.1) board and no other devices are connected to it
OK, great. The ESP8266 microcontroller on your "NodeMcu" board must be put into a special "bootloader mode" during the upload. One of the possible causes of the error you encountered is that the microcontroller was not in that mode.
Normally the boards have a special circuit that automatically puts the microcontroller into bootloader mode. It is possible that the circuit on your board is not working. If so, you should be able to fix the problem by manually putting the board into the appropriate mode before starting an upload.
Please try this:
- Connect the NodeMcu board to your computer with a USB cable.
- Press and hold the button on the board that is labeled "FLASH".
- Press and release the button on the board that is labeled "RST".
- Release the button on the board that is labeled "FLASH".
- Start an upload in Arduino Cloud Editor.
Hopefully this time the upload will be successful.
