Why am I getting this error?
I am getting this error. Any idea? It doesnt make sense to add another } at the end
Beam_break_sensor_new1:170: error: expected '}' at end of input
//Diesels High Tech Pet beam break sensor
//This sketch activates and deactivates the "hold Up" function which is build into the HIGH TECH pet door
//By imitating pressing and holding "ON BUTTON" while pressing "OPEN BUTTON" and then releasing both buttons
enum State {
  IDLE, PAUSE_BEFORE_ON, ON_DELAY, OPEN_DELAY, WAIT_BEAM, PAUSE_BEFORE_CLOSE, OFF_DELAY
} state = IDLE;
uint32_t start_time;
const uint32_t PAUSE_BEFORE_ON_ms = 10L * 1000L; //pause for 10 seconds before initiating sequence
const uint32_t ON_DELAY_ms = 500L;  // pause for half a second before sending ON signal
const uint32_t OPEN_DELAY_ms = 500L;  // pause for half a second before sending OPEN signal
const uint32_t PAUSE_BEFORE_CLOSE_ms = 2L * 1000L; // pause for 2 seconds before sending ground signal to openPin which deactivates "hold Up" function
const uint32_t OFF_DELAY_ms = 250L;// pause for quarter of a second
const boolean SNEAK = true;
const uint32_t SNEAK_TIME = 3000L;// Time to get out the door
const byte onPin = 2;    // On button
const byte openPin = 3;  // Open button
const byte beamPin = 4;  // QT50CM yellow wire of receiver
void activateButton(byte pin) {
  // to activate a button, we ground the pin
  pinMode(pin, OUTPUT);
  digitalWrite(pin, LOW);
void deactivateButton(byte pin) {
  // to deactivate a button, we float the pin
  pinMode(pin, INPUT);
  deactivateButton(onPin);
  deactivateButton(openPin);
  pinMode(beamPin, INPUT_PULLUP);  // turn on internal 5.1k pullup resistor
  state = IDLE;
  start_time = millis();
boolean beamIsBroken() {
  //'broken beam' grounds the output
  return digitalRead(beamPin) == LOW;
  --wait for beam to break (IDLE)
  --beam breaks
  --wait 10 seconds  (PAUSE_BEFORE_ON)
  --send signal to ON
  --wait half a second  (ON_DELAY)
  --send signal to OPEN
  --wait half a second  (OPEN_DELAY)
  --release/turn off/float both signals
  --wait for beam to reconnect  (WAIT_BEAM)
  --wait another 2 seconds (PAUSE_BEFORE_CLOSE)
  --send ground signal to ON(which deactivates function)
  --wait 1/4 of a second (OFF_DELAY)
  --turn off "hold Up funtion" by sending ground signal to openPin
  --wait for beam to break again  (IDLE)
  /**If the beam is broke, wait three seconds
  Then check if the beam is still broke.
  If so, set SNEAK false, otherwise keep it true **/
  if ( beamIsBroken() && state == IDLE ) {
    delay(SNEAK_TIME);
    if (beamIsBroken()) {
      SNEAK == false;
      SNEAK == true;
    }//close if/else
  }//close if
switch (state) {
    case IDLE:
      if (SNEAK == false) {
        state = PAUSE_BEFORE_ON;
        SNEAK == false;
  switch (state) {
    case IDLE:
    case PAUSE_BEFORE_ON:
      if (millis() - start_time >= PAUSE_BEFORE_ON_ms) {
        state = ON_DELAY;
    case ON_DELAY:
      if (millis() - start_time >= ON_DELAY_ms) {
        state = OPEN_DELAY;
    case OPEN_DELAY:
      if (millis() - start_time >= OPEN_DELAY_ms) {
        state = WAIT_BEAM;
    case WAIT_BEAM:
      if (!beamIsBroken()) {
        state = PAUSE_BEFORE_CLOSE;
    case PAUSE_BEFORE_CLOSE:
        state = WAIT_BEAM;
      else  if (millis() - start_time >= PAUSE_BEFORE_CLOSE_ms) {
        state = OFF_DELAY;
    case OFF_DELAY:
      if (millis() - start_time >= OFF_DELAY_ms) {
        state = IDLE;
SNEAK == true;
SNEAK == false;
Careful = vs ==
Which closing brace } ends your loop() function?
diebog:
It means you either forgot to put a '}' somewhere or you put in an extra '{' somewhere. Every '{' needs a matching '}' and the compiler reached the end of the sketch with one more '{' than '}'.
LarryD:
SNEAK == true;
SNEAK == false;
Careful = vs ==
Where did I use = and not ==? I cant find it.
See
https://www.arduino.cc/en/Reference/If
Go through the code 'you' wrote, I am sure you will find all of them.
At the top of loop.
There is an amazing thing called textual search, though I found it in 20 seconds just looking.
diebog:
You used == and not =
