All my libraries are installed, I'm using the newest version of Arduino:
In file included from c:\users\20col\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\include\c++\4.8.2\algorithm:61:0,
from C:\Users\20col\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.2\cores\esp8266/Arduino.h:237,
from C:\Users\20col\Documents\Arduino\libraries\tm1638-library-master\TM16XX.cpp:20:
c:\users\20col\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:193:5: note: template const _Tp& std::min(const _Tp&, const _Tp&)
min(const _Tp& __a, const _Tp& __b)
c:\users\20col\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:193:5: note: template argument deduction/substitution failed:
C:\Users\20col\Documents\Arduino\libraries\tm1638-library-master\TM16XX.cpp:56:57: note: deduced conflicting types for parameter 'const _Tp' ('int' and 'byte {aka unsigned char}')
sendCommand(0x80 | (active ? 8 : 0) | min(7, intensity));
Multiple libraries were found for "TM1638.h"
Used: C:\Users\20col\Documents\Arduino\libraries\tm1638-library-master
Multiple libraries were found for "Timer.h"
Used: C:\Users\20col\Documents\Arduino\libraries\Timer-master
exit status 1
Error compiling for board LOLIN(WEMOS) D1 R2 & mini.
option enabled in File -> Preferences.
Here's the code I'm trying to run on 7 led #include <TM1638.h>#include <Timer.h>bool enabled = false; // counting is - Pastebin.com
