Why arduino "ignore" %
Hi, I just started programing for Arduino with "Getting Started Guide" and I programming by myself. I don't copy. I have problem. I wrote program and i used %. Program doesn't work well but it's good I thing. Its third program - " Example 03A: Turn on LED when the button is pressed and keep it on after it is released"
I know i can write program like man in the book but its good to know for future.
const int LED = 13;
const int BUTTON = 7;
int val = 1;
int p = 1;
pinMode(LED, OUTPUT);
pinMode(BUTTON, INPUT);
val == digitalRead(BUTTON);
//Podmínka pro prepinac
if (val == 1) {
p = p + 1;
// Podminka pro svetlo
if ((p % 2) == 0) {
digitalWrite(LED, HIGH);
else {
digitalWrite(LED, LOW);
Thank you very much :wink:
The loop() will happen tens of thousands of times a second in that code, so unless you can see a light blinking that quickly, it will look like the light is always on.
Just to prove a point, add the following line at the end of your loop:
delay(100);
Is it doing what you expect now?
Try reducing the delay time. Notice what is happening?
As a side note, don't compare the return value of digitalRead() to 1 or 0, compare it to HIGH or LOW. For all you know, one day Arduino might make digitalRead() return 2 and your code won't work anymore, whereas if you use HIGH, it probably would still.
Ok. I made probably some mistake in program - thats why It wont stay turned off so it's not because of "%". I was sure I did no mistake but I probably did. Sorry for spam with so silly problem. I'am happy that I can use in the future "%". Thanks :wink:
Here, you are comparing val to the result of reading the pin state, and discarding the result. You are not assigning the result of the read to the variable.
PaulS:
YES! You're right. I'am happy I programmed well. Stupid mistake. :wink: Thank you
