As I asked upon here In try to initiate sdata sending via serial and read the via python.
What I want is to send an ACK signal in order to initiate the data sending:
import serial
from time import sleep
import base64
def ACK():
ser.write(0x06)
ser.write(0xD)
ser.write(0xA)
ser = serial.Serial('/dev/ttyACM0', baudrate=9600, timeout=1)
if not ser.isOpen():
ser.open()
print("OPEN Serial\n")
print("READ DATA\n")
while 1:
ACK()
line = ser.readline()
if(line == b""): continue;
if(line[:1] == b'2'):
print("DATA:")
print(line)
print("####")
And receive it via this sketch:
#define LASTBLOCK 1023
#define LASTPAGE 63
#define LASTBYTE 2111
#define PAGE_READ 0x13
#define PAGE_READ_CACHE_SEQUENCIAL 0x03
#define READ_FROM_CACHE 0x3B
#define PAGE_READ_CACHE_END 0x3F
#define PAGE_SIZE 2111
#define BUFFER_LEN 32
#define ACK 0x06
#define NACK 0x06
unsigned int page_to_read = 1;
unsigned int block_to_read = 1;
boolean spi_begun = false;
uint8_t bytes_index = 1;
typedef struct {
// Page that is transmitted
unsigned int page;
// Block that is transmitted
unsigned int block;
// A mumeric representation of the 32 byte segment that I send.
// I cannot send the page altogether, therefore a byte intexing is required
uint8_t bytes_index;
// Despite my buffer is 32 bytes the usable data may be less
uint8_t length;
// Data buffer containing the data to be sent via serial
byte data[BUFFER_LEN];
} usb_msg;
void sendMsg(usb_msg msg){
byte* ptr = (byte*)&msg;
Serial.print(0x02);
for (size_t i = 0; i < sizeof(usb_msg); i++){
Serial.print(*ptr >>4, HEX);
Serial.print(*ptr & 0x0F, HEX);
ptr++;
Serial.print(0x03);
bool clientAck()
uint8_t incomingByte = NULL;
digitalWrite(13,HIGH);
do {
uint8_t incomingByte = Serial.read();
} while(incomingByte!=ACK);
digitalWrite(13,LOW);
pinMode(13,OUTPUT);
// I need to reset the counts before reading any block
if(page_to_read > LASTPAGE){
page_to_read = 1;
block_to_read ++;
if(block_to_read > LASTBLOCK){
spi_begun=false;
return ;
if(!spi_begun){
spi_begun=true;
clientAck();
// Reading page there's no need for seperate function in order to avoid stack usage
for(int bytes_to_read = PAGE_SIZE; bytes_to_read > 0; bytes_to_read-=BUFFER_LEN){
uint8_t bytes_to_send = bytes_to_read < BUFFER_LEN ? bytes_to_read: BUFFER_LEN;
usb_msg msg = {page_to_read, block_to_read, bytes_index, bytes_to_send, {1, 1, 1, 1, 1, 1, 1, 1, 1, 1}};
sendMsg(msg);
delay(100);
bytes_index++;
page_to_read++;
delay(100);
But arduino in:
bool clientAck()
uint8_t incomingByte = 0;
do {
Waits forever, do you know why?
What I try to do is to dump a serial flash memory and as a first step I try to wirte the USB IO code, so I can focus on dumping itself as a latter step.
