Why are MCP23017 (port extender) input pins high by default?
wvmarle:
Outputs are routinely designed to be active high with pull-down resistor... especially if there's a MOSFET connected to them.
Or also routinely designed to be active low with pull-up resistor... especially if there's a logic-level device connected to them.
Having the source voltage contained within the device receiving the control signal tends to make the interconnection more "fail-safe" in terms of accidental shorts.
