I'm using the code at the bottom, an example of what I am seeing is shown with the quoted Serial Out Data. When I send a command that updates an eeprom address (12), the previous address (11) becomes NULL . I've bolded where it happens.
What am I doing wrong with my EEProm writing that is causing this?
(Arduino Mega 2560)
Serial Out Data
20:11:28.630 -> dmEEPromValue: Sp
20:11:28.630 -> tcEEPromValue: NULL
20:11:28.640 -> tsEEPromValue: NULL
20:11:28.640 -> Sending Bluetooth Data
20:11:28.644 ->
20:11:33.543 ->
20:11:33.543 -> dmEEPromValue: Sp
20:11:33.543 -> tcEEPromValue: NULL
20:11:33.574 -> tsEEPromValue: NULL
20:11:33.606 -> Sending Bluetooth Data
20:11:33.649 ->
20:11:37.593 -> New data (serialInString): TCEnabled
20:11:37.625 ->
20:11:37.625 -> serialInString: TCEnabled
20:11:37.656 ->
20:11:37.656 -> TC selection: Enabled
20:11:37.689 -> writeToEEProm, settingName: tc , settingValue: Enabled
20:11:38.534 ->
20:11:38.534 -> dmEEPromValue: NULL
20:11:38.569 -> tcEEPromValue: Enabled
20:11:38.599 -> tsEEPromValue: NULL
20:11:38.599 -> Sending Bluetooth Data
20:11:38.636 ->
20:11:43.555 ->
20:11:43.555 -> dmEEPromValue: NULL
20:11:43.555 -> tcEEPromValue: Enabled
20:11:43.669 -> tsEEPromValue: NULL
20:11:43.669 -> Sending Bluetooth Data
20:11:43.669 ->
20:11:48.533 ->
20:11:48.533 -> dmEEPromValue: NULL
20:11:48.687 -> tcEEPromValue: Enabled
20:11:48.687 -> tsEEPromValue: NULL
20:11:48.687 -> Sending Bluetooth Data
Code
#include <EEPROM.h>
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(12, 13); // RX , TX
unsigned long currentTime;
unsigned long btLastSendTimeStamp;
unsigned long currentTimeStamp;
// Serial In/Out Variables
String serialInString;
boolean newData = false;
String readFromEEPROM(String settingName)
if (settingName == "dm")
int address = 11;
int value = -1;
int EEPromValue = EEPROM.get(address, value);
String str_EEPromValueValidate = String(EEPromValue);
String str_EEPromValue = "NULL";
if (validateDataType("int", str_EEPromValueValidate.c_str()) == 0)
return (str_EEPromValue);
if (EEPromValue == 1)
str_EEPromValue = "Ec";
else if (EEPromValue == 2)
str_EEPromValue = "Std";
else if (EEPromValue == 3)
str_EEPromValue = "Sp";
else if (EEPromValue == 4)
str_EEPromValue = "Cu";
else if (settingName == "tc")
int address = 12;
int value = -1;
str_EEPromValue = "Enabled";
str_EEPromValue = "Disabled";
else if (settingName == "ts")
int address = 13;
int value = -1;
str_EEPromValue = "Fr";
str_EEPromValue = "Re";
str_EEPromValue = "Trk";
} // readFromEEPROM
String writeToEEProm (String settingName, String settingValue)
Serial.print("writeToEEProm, settingName: "); Serial.print(settingName); Serial.print(" , settingValue: "); Serial.println(settingValue);
int setting = NULL;
if (settingValue == "Ec")
setting = 1;
else if (settingValue == "Std")
setting = 2;
else if (settingValue == "Sp")
setting = 3;
else if (settingValue == "Cu")
setting = 4;
int address = 11;
EEPROM.put(address, setting);
int setting = NULL;
if (settingValue == "Enabled")
setting = 1;
else if (settingValue == "Disabled")
setting = 2;
int address = 12;
else if (settingName == "tS")
int setting = NULL;
if (settingValue == "Fr")
setting = 1;
else if (settingValue == "Re")
setting = 2;
else if (settingValue == "Trk")
setting = 3;
int address = 13;
return "1";
} // writeToEEProm
bool validateDataType(String dataType, char* data) // true is indeed 1, and false is 0.
if (dataType == "string")
for (int i = 0; i < strlen(data); i++)
if (isAlpha(data[i]))
// continue
return false;
return true;
else if (dataType == "int")
if (isDigit(data[i]))
// continue
return false;
return true;
else if (dataType == "float")
int decimalPointCount = 0;
// continue
else if (data[i] == '.')
decimalPointCount++;
if (decimalPointCount > 1)
return false;
return false;
if (decimalPointCount != 1)
return false;
return true;
} // validateDataType
//BTSerial.begin(38400); // HC-05 default speed in AT command mode
BTSerial.begin(9600);
while (!Serial)
; // Wait for serial to connect
while (!BTSerial)
; // Wait for BTSerial to connect
delay(2000);
Serial.println("Bluetooth Started");
btLastSendTimeStamp = millis();
} // Setup
serialInString = "";
while(Serial.available()>0 && newData == false)
serialInString = Serial.readString();
Serial.print("New data (serialInString): "); Serial.println(serialInString);
newData = true;
delay(15);
/*while(BTSerial.available()>0 && newData == false)
serialInString = BTSerial.readString();
Serial.print("New data: "); Serial.println(serialInString);
newData = true;
delay(15);
String getEEPromValue = "NULL";
getEEPromValue = readFromEEPROM("dm");
String dmEEPromValue = "NULL";
if (getEEPromValue != "NULL")
dmEEPromValue = getEEPromValue;
getEEPromValue = readFromEEPROM("tc");
String tcEEPromValue = "NULL";
tcEEPromValue = getEEPromValue;
getEEPromValue = readFromEEPROM("ts");
String tsEEPromValue = "NULL";
tsEEPromValue = getEEPromValue;
currentTimeStamp = millis();
if ((currentTimeStamp - btLastSendTimeStamp) > 5000)
Serial.println("");
Serial.print("dmEEPromValue: "); Serial.println(dmEEPromValue);
if (dmEEPromValue != "NULL")
//Serial.print("(!=NULL)lblDMV="); Serial.println(dmEEPromValue);
Serial.print("tcEEPromValue: "); Serial.println(tcEEPromValue);
if (tcEEPromValue != "NULL")
//Serial.print("(!=NULL)lblTCV="); Serial.println(tcEEPromValue);
Serial.print("tsEEPromValue: "); Serial.println(tsEEPromValue);
if (tsEEPromValue != "NULL")
//Serial.print("(!=NULL)lblTSV="); Serial.println(tsEEPromValue);
Serial.println("Sending Bluetooth Data");
Serial.println("");
if (serialInString != "")
Serial.print("serialInString: "); Serial.println(serialInString);
if ((serialInString == "Ec" || serialInString == "Ec\r\n") && (newData == true))
Serial.print("DM selection: ");
Serial.println("Ec");
writeToEEProm("dm", "Ec");
newData = false;
else if ((serialInString == "Std" || serialInString == "Std\r\n") && (newData == true))
Serial.println("Std");
writeToEEProm("dm", "Std");
newData = false;
else if ((serialInString == "Sp" || serialInString == "Sp\r\n") && (newData == true))
Serial.println("Sp");
writeToEEProm("dm", "Sp");
newData = false;
else if ((serialInString == "Cu" || serialInString == "Cu\r\n") && (newData == true))
Serial.println("Cu");
writeToEEProm("dm", "Cu");
newData = false;
else if ((serialInString == "TCEnabled" || serialInString == "TCEnabled\r\n") && (newData == true))
Serial.print("TC selection: ");
Serial.println("Enabled");
writeToEEProm("tc", "Enabled");
newData = false;
else if ((serialInString == "TCDisabled" || serialInString == "TCDisabled\r\n") && (newData == true))
Serial.println("Disabled");
writeToEEProm("tc", "Disabled");
newData = false;
else if (serialInString == "Fr" && newData == true)
Serial.print("TS selection: ");
Serial.println("Fr");
writeToEEProm("ts", "Fr");
newData = false;
else if (serialInString == "Re" && newData == true)
Serial.println("Re");
writeToEEProm("ts", "Re");
newData = false;
else if (serialInString == "Trk" && newData == true)
Serial.println("Trk"); // Send back, to the phone, the String "LED: ON"
writeToEEProm("ts", "Trk");
newData = false;
