This is my code:
#include <LiquidCrystal_I2C.h> // Use I2C library
const int address = 0x27; // Replace with your LCD's I2C address if different
LiquidCrystal_I2C lcd(address, 16, 2); // Define LCD dimensions
// Define the number of samples and curves
const int numSamples = 50;
const int numCurves = 4;
// Arrays to store collected data and existing curves
float collectedData[numSamples];
float existingCurves[numCurves][numSamples];
float voltage[numSamples];
// Names of the existing curves
const char* curveNames[] = {"low MIC", "CEF MIC", "CIP MIC", "GEN MIC"};
Wire.begin(); // Initialize I2C communication
lcd.init(); // Initialize the LCD
lcd.backlight(); // Turn on the backlight (optional)
// Initialize the existing curves (no need for loading here)
float existingCurves[numCurves][numSamples] = {
{8.5338, 7.7862, 3.8893, 2.0185, 1.1925, 0.7812, 0.55199, 0.41257, 0.32192, 0.25984, 0.21554, 0.18285, 0.15807, 0.13884, 0.12362, 0.11138, 0.10138, 0.093122, 0.08621, 0.080376, 0.075397, 0.071127, 0.067434, 0.064208, 0.061389, 0.058898, 0.056694, 0.054737, 0.052977, 0.051408, 0.049988, 0.048709, 0.04755, 0.046495, 0.04553, 0.044646, 0.043841, 0.043096, 0.042412, 0.041777, 0.04119, 0.040648, 0.040143, 0.03967, 0.039233, 0.038829, 0.038444, 0.038089, 0.03775, 0.03743
}, // Curve 1
{8.534, 8.2735, 6.9479, 5.6951, 4.6544, 3.8372, 3.2085, 2.7273, 2.3588, 2.0768, 1.862, 1.7003, 1.5813, 1.4971, 1.4414, 1.4089, 1.3954, 1.3969, 1.4103, 1.4326, 1.4611, 1.4936, 1.5281, 1.5631, 1.5973, 1.6295, 1.6592, 1.6858, 1.7091, 1.7289, 1.7454, 1.7587, 1.7691, 1.7769, 1.7825, 1.7861, 1.7881, 1.7887, 1.7884, 1.7873, 1.7855, 1.7834, 1.781, 1.7784, 1.7757, 1.773, 1.7703, 1.7677, 1.7651, 1.7627
}, // Curve 2
{8.3963, 8.3099, 7.784, 7.2455, 6.7251, 6.2413, 5.803, 5.4127, 5.0688, 4.7677, 4.5049, 4.2758, 4.0759, 3.9011, 3.748, 3.6135, 3.495, 3.3903, 3.2973, 3.2146, 3.1408, 3.0747, 3.0153, 2.9618, 2.9134, 2.8696, 2.8297, 2.7934, 2.7603, 2.7299, 2.7021, 2.6765, 2.6529, 2.6312, 2.611, 2.5924, 2.575, 2.5589, 2.5439, 2.5299, 2.5169, 2.5047, 2.4932, 2.4825, 2.4724, 2.463, 2.4539, 2.4454, 2.4368
}, // Curve 3
{8.4942, 7.972, 5.7531, 4.3652, 3.6053, 3.1739, 2.9129, 2.7453, 2.6321, 2.5524, 2.4943, 2.4508, 2.4173, 2.391, 2.3701, 2.3531, 2.3392, 2.3276, 2.3178, 2.3095, 2.3025, 2.2964, 2.2911, 2.2865, 2.2824, 2.2788, 2.2757, 2.2728, 2.2703, 2.268, 2.2659, 2.2641, 2.2624, 2.2608, 2.2594, 2.2581, 2.257, 2.2559, 2.2549, 2.2539, 2.2531, 2.2523, 2.2515, 2.2508, 2.2502, 2.2496, 2.249, 2.2485, 2.248
} // Curve 4
// Display "loading" message initially
lcd.clear();
lcd.print("Loading...");
// Collect samples evenly for 1 hour
unsigned long startTime = millis();
unsigned long interval = 3600000 / numSamples; // Calculate interval for evenly spaced samples
for (int sampleIndex = 0; sampleIndex < numSamples; sampleIndex++) {
unsigned long targetTime = startTime + interval * sampleIndex;
while (millis() < targetTime) { // Wait until the target time for this sample
; // Do nothing, just wait
collectedData[sampleIndex] = analogRead(A0);
voltage[sampleIndex] = (collectedData[sampleIndex] * 5.0) / 1023.0;
Serial.println(voltage[sampleIndex]); // Print the specific voltage value
// Clear the loading message and display results
lcd.clear();
// Find the curve with the highest correlation
int highestCorrelationIndex = 0;
float highestCorrelation = 0;
for (int i = 0; i < numCurves; i++) {
float correlation = calculateCorrelation(voltage, existingCurves[i]);
if (correlation > highestCorrelation) {
highestCorrelation = correlation;
highestCorrelationIndex = i;
// Display the name of the curve with the highest correlation
lcd.clear();
lcd.print("Highest Correlation:");
lcd.setCursor(0, 1);
lcd.print(curveNames[highestCorrelationIndex]);
// Function to calculate correlation coefficient (Pearson's correlation)
float calculateCorrelation(float data1[], float data2[]) {
float mean1 = 0, mean2 = 0;
for (int i = 0; i < numSamples; i++) {
mean1 += data1[i];
mean2 += data2[i];
mean1 /= numSamples;
mean2 /= numSamples;
float numerator = 0, denominator1 = 0, denominator2 = 0;
numerator += (data1[i] - mean1) * (data2[i] - mean2);
denominator1 += (data1[i] - mean1) * (data1[i] - mean1);
denominator2 += (data2[i] - mean2) * (data2[i] - mean2);
return numerator / sqrt(denominator1 * denominator2);
I get an error saying the break is not in a loop or switch. is a Void loop, not a loop?
PAO1:73:3: error: break statement not within loop or switch
exit status 1
