when i added the transmissopn library (virtual wirel.h) and the transmission settings my screen went empty and when i removed all the settings i got my display back can anyone help ??
You can use the 2 together.
I am doing so.
Nobody can help you if you don't post information.
You could be using conflicting libraries fighting for the same resources.
I suggest you do the following...
Take a basic example from the Virtualwire library and from the LCD library.
Combine the 2 sketches.
Get that to work then add it to your project sketch.
#include <VirtualWire.h>
#include <VirtualWire_Config.h>
#include <LiquidCrystal.h>
#include <Wire.h>
#include <RTClib.h>
RTC_DS1307 RTC;
LiquidCrystal lcd(13,11,5,4,3,2);
byte zero = 0x00;
int button1=9;
int button2=8;
int button3=7;
int button1state=0;
int button2state=0;
int button3state=0;
int prevbutton1state=0;
int prevbutton3state=0;
int Smodeenabled=0;
int Vmode=0;
void setup () {
Wire.begin();
RTC.begin();
lcd.begin(16,2);
pinMode(button1,INPUT);
pinMode(button3,INPUT);
// following line sets the RTC to the date & time this sketch was compiled
//RTC.adjust(DateTime(__DATE__, __TIME__));
void loop () {
DateTime now = RTC.now();
button1state=digitalRead(button1);
delay(1);
button2state=digitalRead(button2);
delay(1);
button3state=digitalRead(button3);
if(button1state != prevbutton1state){
if(button1state==HIGH){
Smodeenabled = !Smodeenabled;}}
if(button3state != prevbutton3state){
if(button3state==HIGH){
Vmode=!Vmode;}}
/*if(Vmode=0){
lcd.display();}
else{
lcd.noDisplay();}*/
print_date();
if(button2state==HIGH){
send_the_go();
prevbutton3state=button3state;
prevbutton1state=button1state;}
void smartmode(){
if(now.dayOfWeek()==0){}
else if(now.dayOfWeek()<5){
if(now.hour()==7 && now.minute()==55 && now.second()>=00 && now.second()<=2 ){
send_the_go();}
if(now.hour()==8 && now.minute()==55 && now.second()>=00 && now.second()<=2){
send_the_go(); }
if(now.hour()==9 && now.minute()==55 && now.second()>=00 && now.second()<=2){
send_the_go();}
if(now.hour()==10 && now.minute()==05 && now.second()>=00 && now.second()<=2){
send_the_go(); }
if(now.hour()==11 && now.minute()==00 && now.second()>=00 && now.second()<=2){
send_the_go(); }
if(now.hour()==12 && now.minute()==00&& now.second()>=00 && now.second()<=2){
send_the_go(); }
if(now.hour()==13 && now.minute()==55 && now.second()>=00 && now.second()<=2){
send_the_go(); }
if(now.hour()==14 && now.minute()==55 && now.second()>=00 && now.second()<=2){
send_the_go(); }
if(now.hour()==15 && now.minute()==55 && now.second()>=00 && now.second()<=2){
send_the_go(); }
if(now.hour()==16 && now.minute()==05 && now.second()>=00 && now.second()<=2){
send_the_go(); }
if(now.hour()==17 && now.minute()==00 && now.second()>=00 && now.second()<=2){
send_the_go(); }
if(now.hour()==18 && now.minute()==00 && now.second()>=00 && now.second()<=2){
send_the_go();}}
else {
send_the_go();}
send_the_go(); }
send_the_go(); }
send_the_go(); }
send_the_go(); }}}
void send_the_go (){
const char *msg = "I m Arduino ";
digitalWrite(13, true);
vw_send((uint8_t *)msg, strlen(msg));
vw_wait_tx();
Serial.println("The Message is Successfully Sent! ");
digitalWrite(13,false);
delay(1000);}
void print_date(){
lcd.clear();
lcd.setCursor(0,1);
lcd.print("mode auto:");
lcd.home();
lcd.print(now.year(), DEC);
lcd.print('/');
lcd.print(now.month(), DEC);
lcd.print('/');
lcd.print(now.day(), DEC);
lcd.print(' ');
lcd.print(now.hour(), DEC);
lcd.print(':');
lcd.print(now.minute(), DEC);
lcd.setCursor(11,1);
if(Smodeenabled==0){
Serial.println("0");
delay(10);
lcd.print("off");
delay(10);}
else {
Serial.println("1");
lcd.print(" ");
lcd.print("on");
delay(250);
lcd.noAutoscroll();
smartmode();}
void second_screen(){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("****sonnerie****");
lcd.setCursor(1,1);
lcd.print("*****actif*****");}
and when i add this line
vw_set_ptt_inverted(true);
vw_setup(2000);
booooooooom i lost all the display can someone help
Why do you need VirtualWire, instead of only the Wire library?
In
you can configure which pins are used by the LCD, in case some other library also uses the given default pins.
i need virtual wire for the rf433 do you have any subbtitute code for the rf ???
I believe your problem is conflicting libraries.
You did not take my advise of creating a test script - ce la vie.
There are alternative RF libraries. I use Virtualwire, RCSwitch and RH_ASK.
However, I think you will find u need to change the LCD library.
Try the Francisco Malpartida library, it is what I use with Virtualwire.
Do a search on Github for it.
Again I advise, start with a simple sketch and see what works, then introduce it to your project sketch.
thx anyway i figured out i had a conflict in pins i fixed it thx anyway appreciated your help
hey can i use this piece of code to set aveille screen
if(Vmode=0){
lcd.display();}
else{
lcd.noDisplay();}
This is incorrect : if(Vmode=0)
It depends on what you want to achieve with the veil.
You need to specify exactly what you are trying to do.
But if u don't want to display anything at all, why initialise the LCD to start with?
if(Vmode=0) is never correct. = is assignment, == is comparison. if(Vmode==0) is potentially what you want.
