system
January 1, 2009, 10:58pm
1
I'm trying to do something fairly simple. Just generate a pitch sweeping tone using interrupts but I'm not getting a lot of success.
The OCR0A doesn't seem to change. What am I doing wrong.
#include <avr/interrupt.h>
pinMode(6,OUTPUT);
TCCR0A = _BV(COM0A0) | _BV(WGM01); // toggle output set mode to ctc
TCCR0B = _BV(CS01) | _BV(CS00); // CTC mode and prescaler to 64
OCR0A = 10;
unsigned char timer_val = 100;
for (timer_val=10; timer_val < 250; timer_val++);
OCR0A = timer_val;
delay (500);
system
January 2, 2009, 11:24am
2
Okay. I got it to work but with a problem.
Here is the working code. Sounds like a siren.
#ifndef cbi // Definitions for setting and clearing register bits
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
pinMode(6,OUTPUT);
OCR0A = 10;
for (unsigned char timer_val=0; timer_val<250; timer_val++)
cbi(TCCR0A,COM0A0) ; // disconnect pulse clock
OCR0A = timer_val; // update timer value
sbi(TCCR0A,COM0A0) ; // connect pulse clock
Serial.print(timer_val);
But I can't add a delay in the for loop. Any ideas why a delay won't work anymore?
mem
January 2, 2009, 11:45am
3
That code is using timer0 - this is the timer used by the delay function! Use timer1 or timer2 and you will get your delay functions back
system
January 2, 2009, 12:26pm
4
Thanks for your help. I'm very new to Arduino. I'll try timer1 or timer2 and let you know how I get on.
