hi i have a problem with my Digilent chipKIT Uno32 board when i upload a sketch it says that upload is complete but it says: "avrdude: stk500_getsync(): not in sync: resp=0x00" what does that mean? and how does i solve it?
It means that your computer can't see the USB / serial bridge.
Have you installed the drivers.
Not that Digilent chipKIT Uno32 is not a proper Arduino but something cashing in on the Arduino's sucess by pretending it is similar. In fact it is a very different beast.
does that mean that it would be easier with a real Arduino microcontroller?
Well you could get more help here.
This should be in the installation & trouble shooting section. Go there and read the first post. It is a sticky and tells you what to do with problems like this.
I got almost the same error
I use Duemilanove ATMEGA 328
It work just find until I upload the code that seem to be the reason
after upload this code when I try to upload a new code I will get an error message;
avrdude: stk500_getsync(): not in sync: resp=0x30
First, I thought that the chip is broken so I use another arduino and right after I upload the same code, it has the same problem
here is the code;
#include <Reflector.h>
#include <Move.h>
Move move(2,3,4,5,10,11); //first four pin for each 2 input of each motor(2 motor)
//last two for enable input of ic
Reflector reflector(200);
int dim = 5;
int y = ((dim-1)/2) +1 ;//initial y position
int l = 0;
int r = 1;
int t = 0;
void setup(){
void loop(){
int inten0, inten1, inten2;
int sensor0, sensor1, sensor2;
sensor0 = reflector.sensor(0); // analorRead pin input of each sensor
sensor1 = reflector.sensor(1);
sensor2 = reflector.sensor(2);
inten0=reflector.reference(sensor0);
inten1=reflector.reference(sensor1);
inten2=reflector.reference(sensor2);
Serial.print(inten0);
Serial.print(" ");
Serial.println(inten1);
move.speed(100,90);
if(inten0 == 1 && inten1 == 1 && y <dim){
move.forward();
y++;
if(inten0 == 0 && inten1 == 1 && y == dim && r==1 ){
move.left();
y = 0;
t++;
l==1;
r==0;
if(inten0 == 1 && inten1 == 0){
move.right();
y = 0;
t++;
l==0;
r==1;
if(t==8&&y==dim){
move.stop();
delay(50);
So, anyone have any idea
Sure. Two different Arduinos having problems with UPLOADING code means that it is NOT a programming issue. So, follow the directions on the IDE when the upload fails. Whining in the wrong section of the forum is WAY down on the list of things to do.
