Ok I've been with arduino for a while now and I've got a question that's been burning me for a while now.
If arduino uses CPP files to create its libraries then why can't you open them using arduino. It kind of doesn't make since to me that I have to download a whole separate application like VSE to alter the files.
I just use VSE, and no my notepad will not open .cpp or .h files.
Don't need to move or copy a file I can copy and paste any file which is what I do when working on a library so I have an un-modified version but I still think you should be able to open any arduino file whether in arduino or C using the IDE.
I'm just wondering why it's not like that already?
The Arduino IDE has "requirements" about file location and directory names for its projects ("sketches.")
You can't open a ".ino" file that isn't in the right place, either (although if you try, the IDE will offer to adjust everything so that it will work.) Within a proper sketch directory, you shouldn't have any trouble opening .cpp files.
(and yes, I think this means that you can't use the IDE directly to edit library files.)
westfw:
You just need to trick the IDE into thinking it's a sketch by adding a dummy .ino file with the same name as the folder. Files in the libraries folders are treated as read only so you also need to add a file named .development to the library folder.
Duhjoker:
As standard notepad from windows only lists 'Tet Documents (.txt)' in open file dialog. To see other files change to 'all files (.*)' to the right of name field.
