int led1=2;
pinMode(led1,OUTPUT);// put your setup code here, to run once:
int sensorValue2=analogRead(A2);
if (sensorValue2>=600&& sensorValue2<=800){
Serial.println(sensorValue2);
digitalWrite(led1,HIGH);// put your main code here, to run repeatedly:
else{
digitalWrite(led1,LOW);
int sensorValue1=analogRead(A1);
if (sensorValue1>=600&& sensorValue1<=800){
Serial.println(sensorValue1);
else{
What type of sensor ?
How is it wired ?
Does sensor1 work ?
What happens if you exchange the two sensors ?
What do you see when you print the two values ?
Sensor1 generate output but Sensor2 doesnt if I change the names or input from Sensor1 to Sensor2 then Sensor2 generate output but not Sensor1.
Is there a problem with the code?
Connect another Led (led2) at DPin-3 to monitor the status of sensor1's signal. And then, upload the following sketch:
int led1 = 2;
int led2 = 3;
pinMode(led1, OUTPUT); // put your setup code here, to run once:
pinMode(led2, OUTPUT);
int sensorValue2 = analogRead(A2);
if (sensorValue2 >= 600 && sensorValue2 <= 800)
digitalWrite(led1, HIGH); // put your main code here, to run repeatedly:
digitalWrite(led1, LOW);
int sensorValue1 = analogRead(A1);
if (sensorValue1 >= 600 && sensorValue1 <= 800)
digitalWrite(led2, HIGH);
digitalWrite(led2, LOW);
What if i want to be the output be summation of both sensors reading
saquib_12:
Don't you think that it would be better to get both of them (whatever they are) before doing anything else ?
Please answer the questions in reply #1
I have tried connecting everything but problem still there
led1 light up for sensor1 but not for the other one
I have checked both the sensors they work perfectly.
I think theirs a problem with code as it could not generate the summation of output
I think sensor2 actually generate output. But because sensor1 is read immediatly afterwards, it will overwrite the output of sensor2.
Use two leds, or you could put in a delay between readings.
To show sensor2 for 500ms and sensor1 for 1000ms, try this:
Edit:
If you want the LED to show if either of the sensors are in the actual range...
- Read both sensors in beginning of the loop
- Test if sensor1 OR sensor2 is in actual range and write HIGH or LOW to led1 accordingly
- Wait and repeat
