Why data I2c from slave can't transfering to master
Hi Master, Why my program can't transfering data from slave to master, I'm using arduino uno as slave and master
#include <Arduino.h>
#include <Wire.h>
template <typename T> unsigned int I2C_writeAnything (const T& value)
    const byte * p = (const byte*) &value;
    unsigned int i;
    for (i = 0; i < sizeof value; i++)
          Wire.write(*p++);
    return i;
  }  // end of I2C_writeAnything
template <typename T> unsigned int I2C_readAnything(T& value)
    byte * p = (byte*) &value;
    unsigned int i;
          *p++ = Wire.read();
    return i;
  }  // end of I2C_readAnything
master Code
#include <Wire.h>
#include "I2C_Anything.h"
const byte SLAVE_ADDRESS1 = 1;
const byte SLAVE_ADDRESS2 = 2;
 Serial.begin(9600);  // start serial for output
 Wire.onReceive (receiveEvent);
volatile boolean haveData = false;
volatile float tempC;
volatile float h;
 Wire.begin (SLAVE_ADDRESS1 );
    if (haveData)
    Serial.print (tempC);
    delay (1000);
    Serial.print (h);
    haveData = false;
    delay (1000);
 Wire.begin (SLAVE_ADDRESS2 );
  if (haveData)
    delay (1000);
    Serial.print (h);
    haveData = false;
    delay (1000);
   delay (200);
  void receiveEvent (int howMany)
 if (howMany >= (sizeof tempC) + (sizeof h))
   I2C_readAnything (tempC);
   I2C_readAnything (h);
   haveData = true;
   }  // end if have enough data
  // delay(500);
Salve 1 Code
#include <Wire.h>
#include <LiquidCrystal.h>
#include "DHT.h"
#define tempPin A0
#define DHTPIN A1
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
const byte MY_ADDRESS = 1;
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);
float tempC;
pinMode (10, OUTPUT);
pinMode (11, OUTPUT);
pinMode (12, OUTPUT);
lcd.begin(16, 2);
  Wire.begin (MY_ADDRESS);
  Serial.begin (9600);
  //Wire.onRequest(requestEvent);
//delay(100);
float tempC;
float h;
int tempPin = 0;
h = dht.readHumidity();
float t = dht.readTemperature();
tempC = analogRead(tempPin);           //pembacaan nilai dari sensor
tempC = (5.0*tempC*100.0/1024.0);     //Converter dari tegangan ke suhu
  if (isnan(t) || isnan(h)) {
  //Serial.println("Failed to read from DHT");
else {
  lcd.setCursor(0,0);
  lcd.print("Temp=");
  lcd.print(tempC);
  tempC = analogRead(tempPin);           //read the value from the sensor
  tempC = (5.0*tempC *100.0/1024.0);
  lcd.print("  \337C");
  lcd.setCursor(0,1);
  lcd.print("Humidity=");
  lcd.print(h);
  lcd.print("% ");
  delay(100);
  // long foo = 42;
 //for (float fnum = 1; tempC <= 10; fnum += 0.015)
    Wire.beginTransmission (MY_ADDRESS);
    I2C_writeAnything (tempC);
    I2C_writeAnything (h);
    Wire.endTransmission ();
    delay (200);
    }  // end of for
Slave 2
#include <Wire.h>
#include "DHT.h"
#define tempPin A0
#define DHTPIN A1
const byte MY_ADDRESS = 2;
float tempC;
lcd.begin(16, 2);
//delay(100);
float tempC;
float h;
int tempPin = 0;
else {
  lcd.setCursor(0,0);
  lcd.print("Temp=");
  lcd.print(tempC);
  lcd.setCursor(0,1);
  lcd.print(h);
  lcd.print("% ");
  delay(100);
  // long foo = 42;
    delay (200);
    }  // end of for
