Why delay of 1500ms after wire.begin() ?
Hello,
I am wondering why there is a delay in the setup function after initialising the I2C communication. I have connected an MPU6050 to the SDA and SCL pins.
My guess is that it is necessary to wait for the I2C communication to begin? But i can't understand if it's a limitation based on the Arduino or the I2C device, in this case, the MPU6050?
Is 1500ms a common or recommended value for the delay to wait for the I2C communication to be established? There is also another delay of only 2ms after the MPU6050 is initialised?
  Serial.begin(9600);                //open the serial monitor, set the baud rate to 9600
  Wire.begin();                      //join I2C bus sequence
  delay(1500);  //why is this delay here?? and why 1500ms?
   mpu6050.initialize();           //initialize MPU6050
  delay(2);  //why is there another delay here and why is it only 2ms?
Ask whoever wrote the code. I don't know why the delay is there. I have never used a delay after Wire.begin() in any of my programs.
You've asked a lot of questions. Now, let me ask a couple of questions.
What changes happened when you commented out the 1500 millisecond delay()?
What changes happened when you commented out the 2 millisecond delay()?
Why didn't you?
OK, that was three questions...
DryRun:
Hello,
There is no real reason that I can see. The delays are not needed.
