Why different Request Intervals Cause Significant Delay in MODBUS TCP/IP Communication
Hello everyone, I am using Arduino DUE and Arduino Ethernet Shield 2 for MODBUS TCP/IP communication. Specifically, I have the Arduino DUE acting as a MODBUS Master, while the PC serves as the SLAVE using MODBUS Slave software.
When I set the REQUEST_INTERVAL to 2 seconds, the Response time (microseconds) is 378. When I set the interval to 0.02 seconds, the Response time (microseconds) is 19744. Do you think the slowdown is caused by the Arduino DUE being overloaded or the Arduino Ethernet Shield 2 being overloaded?
Here is my code:
#include <SPI.h>
#include <Ethernet.h>
// Pin Definitions
// Network Configuration
byte mac[] = { 0xA8, 0x61, 0x0A, 0xAE, 0x0A, 0xCC };
IPAddress server(192, 168, 123, 209);  // ModbusTCP server address
IPAddress localIP(192, 168, 123, 207); // Local IP address as slave
EthernetClient ethClient;
EthernetServer slaveServer(502);        // Modbus slave server
// ModbusTCP Configuration
uint16_t transactionId = 0;
uint16_t holdingRegisters[100];         // Holding registers array
bool isMasterMode = true;               // Mode switching flag
unsigned long modeChangeTimer = 0;       // Mode change timer
const unsigned long MODE_CHANGE_INTERVAL = 10000; // Mode change interval(ms)
unsigned long requestStartTime = 0;  // Request start time
unsigned long lastRequestTime = 0;   // Last request time
const unsigned long REQUEST_INTERVAL = 2000000; // 2 seconds = 2000000 microseconds
void sendModbusRequest(byte slaveId, byte functionCode, uint16_t startAddr, uint16_t quantity) {
  byte request[12];
  // Modbus TCP Frame Header
  request[0] = highByte(transactionId);
  request[1] = lowByte(transactionId++);
  request[2] = 0x00; // Protocol Identifier High Byte
  request[3] = 0x00; // Protocol Identifier Low Byte
  request[4] = 0x00; // Length High Byte
  request[5] = 0x06; // Length Low Byte
  request[6] = slaveId;
  request[7] = functionCode;
  request[8] = highByte(startAddr);
  request[9] = lowByte(startAddr);
  request[10] = highByte(quantity);
  request[11] = lowByte(quantity);
  ethClient.write(request, 12);
void readModbusResponse() {
  byte buffer[256];
  int len = 0;
  while (ethClient.available() && len < 256) {
    buffer[len++] = ethClient.read();
  if (len > 0) {
    // Serial.print("Response received, length: ");
    // Serial.println(len);
    // Serial.print("Data content: ");
    // // Print each byte in hexadecimal format
    // for(int i = 0; i < len; i++) {
    //   if(buffer[i] < 0x10) {
    //     Serial.print("0"); // Add leading zero
    //   Serial.print(buffer[i], HEX);
    //   Serial.print(" ");
    // Serial.println(); // New line
    // Parse Modbus response
    if(len >= 9 && buffer[7] == 0x03) {  // Verify read holding register response
      byte dataLen = buffer[8];  // Number of data bytes
      if(len >= (9 + dataLen)) {
        // uint16_t registerValue = (buffer[9] << 8) | buffer[10];  // Combine high and low bytes
        // Serial.print("Register value: ");
        // Serial.println(registerValue);
        unsigned long responseTime = micros() - requestStartTime;  // Calculate response time
        Serial.print("Response time (microseconds): ");
        Serial.println(responseTime);
void runMasterMode() {
  if (!ethClient.connected()) {
    if (ethClient.connect(server, 502)) {
      Serial.println("Connected to Modbus server");
      Serial.println("Connection failed");
      return;
    requestStartTime = micros();  // Record sending time
    sendModbusRequest(0x01, 0x03, 0x0000, 0x0001);
    lastRequestTime = micros();
  if (ethClient.available()) {
    readModbusResponse();
  Serial.begin(9600);  // Initialize Serial for debugging
  // Initialize Ethernet
  Ethernet.begin(mac, localIP);
  // Check if sending interval has elapsed
  if (micros() - lastRequestTime >= REQUEST_INTERVAL) {
    runMasterMode();
I would think the Arduino DUE is saturating the capabilities of the Ethernet Shield.
Yes, I think so too. Do you know if there are any Ethernet shields with higher processing capabilities available for Arduino?
I would not know for certain - may be look at Wiznet W6100 based Ethernet Shields.
Do you really need a REQUEST_INTERVAL of 20ms ?
Also - in a busy network with a lot of traffic, a 20 ms interval could lead to collisions or delays, particularly if the devices are not prioritized.
