Why do i get error (void setupTimer() & void TC3_Handler ()) working with Arduino nano 33 iot board but not on Due board with same code?
#include <Arduino.h>
// H-Bridge output pins (Use PWM-capable pins!)
#define DCMOT_EN 4
#define DCMOT_A 2
#define DCMOT_B 3
// Reflex-coupler input pin
#define DCMOT_PULS 5
#define poti A0
#define freq 1
static unsigned long counter_ = 0;
void zaehler();
void zaehler() //zaehler für Counter
    counter_ ++;
void setupTimer (Tc *tc, uint32_t channel, IRQn_Type irq, uint32_t frequency)
pmc_set_writeprotect (false);
pmc_enable_periph_clk((uint32_t) irq);
NVIC_EnableIRQ(irq) ;
TC_Configure(tc, channel, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC | TC_CMR_TCCLKS_TIMER_CLOCK4);
uint32_t rc = (uint32_t) VARIANT_MCK/128/frequency; // (because TIMER_CLOCK4 = MCK/128)
TC_SetRA(tc, channel, rc/2); //50% high, 50% low
TC_SetRC(tc, channel, rc); // set RC (compare vaule)
TC_Start(tc, channel);
tc->TC_CHANNEL[channel].TC_IER=TC_IER_CPCS; // RC compare IRQ
tc->TC_CHANNEL[channel].TC_IDR=~TC_IER_CPCS; // disable all other IRQ sources
// Interrupt Service Routine for TC3-IRO
void TC3_Handler ()
TC_GetStatus(TC1, 0) ;
Serial.println( "Drehzahl pro minute=");
Serial.println((counter_ /8)*60);
counter_ =0;//zürücksetzen des counters
{   // start UART-monitor
// configure pins
pinMode(DCMOT_EN, OUTPUT);
pinMode(DCMOT_A, OUTPUT);
pinMode(DCMOT_B, OUTPUT);
pinMode(DCMOT_PULS, INPUT); // pull-up not required
pinMode(poti, INPUT);
setupTimer(TC1, 0, TC3_IRQn, freq);
Serial.print("1=links\n");
Serial.print("2=stopp\n");
Serial.print("3=rechts\n");
attachInterrupt(digitalPinToInterrupt(DCMOT_PULS), zaehler, FALLING);
    static uint32_t motorMode = 0;
    static uint32_t UI_ActionFlag = 0;
    //int speed = analogRead(poti)/4; //liest potentiometer [0-1023] und wandelt in 0-255 Bereich,
    // angeschlossen in 3.3V
    // int speed = 255; // fest geschwindigkeit
    // === UI ===============================================
    int speed = 128;
    if (Serial.available())
        UI_ActionFlag = 1;
        switch (Serial.read())
            case '3': // rechts
            motorMode = 3;
            case '1': //links
            motorMode = 1;
            case '2': //off
            motorMode = 2;
            default:
            UI_ActionFlag = 0;
    // === Update Motor Mode ================================
    // if (UI_ActionFlag)
    if (true)
        switch (motorMode)
            case 1:
            analogWrite(DCMOT_EN, speed);
            digitalWrite(DCMOT_A, HIGH);
            digitalWrite (DCMOT_B, LOW) ;
            case 3:
            digitalWrite(DCMOT_A, LOW);
            digitalWrite (DCMOT_B, HIGH) ;
            case 2:
            digitalWrite(DCMOT_EN, LOW );
platformio.ini for due board
[env:due]
platform = atmelsam
board = due
framework = arduino
platformio.ini for nano board
[env:nano_33_iot]
platform = atmelsam
board = nano_33_iot
framework = arduino
A DUE (ATMEL SAM3X8E) des not equal a Nano (ATMega4809)
How do i get my error get corrected?
Write timer code for the Due.
The search box is a useful tool.
For instance, using the words "9v battery" in the search box one could find lots of reasons why this may be a bad idea.
Other search words include "level shifter", "round", "millis()", "DUE timer"
It's a Nano 33 IoT (SAMD21G18) :wink: But your point is very valid :+1:
Thanks for the info.
Life is very complicated nowadays with all those different Nanos.
:frowning_face: :frowning_face: :frowning_face:
