why do i get the data (realtime) in 1970-1-1 at 8.0.0 ?
I have been working on monitoring the energy consumption data using pzem004t connected to wemos d1 mini (esp8266). The wemos send the collected data via wifi to the database that i’m using is firebase. The code that i use for coding in wemos d1 mini as following. Everything is fine but the time is wrong my result that shown in the firebase always start from 1970-1-1 at 8.0.30 which i dont understand why. Can anyone help me figure out this problem? thank you.
link for the date error pic
#include <ESP8266WiFi.h>
#include <FirebaseArduino.h>
#include <SoftwareSerial.h> //delete
#include <PZEM004T.h>
#include <time.h>
// Config WiFi
#define WIFI_SSID     "Pengg'"
#define WIFI_PASSWORD "pongpeng"
// Config Firebase
#define FIREBASE_HOST "energy-consumption-database.firebaseio.com"
#define FIREBASE_AUTH "dcnyJmfvSjusinHtsWyicefqfXHvb2vIkkum6EhTJm"
#ifndef min
#define min(a,b) ((a)<(b)?(a):(b))
#endif
float calBill(float Unit, float ft, bool over_150_Unit_per_month = false) ;
// Config time
int timezone = 7;
// Config bill
#define FIX_FT 0
char ntp_server1[20] = "ntp.ku.ac.th";
char ntp_server2[20] = "fw.eng.ku.ac.th";
char ntp_server3[20] = "time.uni.net.th";
int dst = 0;
unsigned long lastUpdateEnergy = 0, lastUpdateFirebase = 0;
float Volt, Amp, Power;
//unsigned long Energy = 0;
float Energy = 0;
PZEM004T pzem(D6, D7);  // (RX,TX) connect to TX,RX of PZEM
IPAddress ip(192, 168, 1, 1);
  while (!pzem.setAddress(ip)) {
    Serial.println("Connecting to PZEM...");
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("connecting");
    Serial.print(".");
  Serial.print("connected: ");
  configTime(timezone * 3600, dst, ntp_server1, ntp_server2, ntp_server3);
  Serial.println("Waiting for time");
  while (!time(nullptr)) {
    Serial.print(".");
  Serial.println("Now: " + getTime());
  Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
  if ((millis() - lastUpdateEnergy) >= 1000) {
    lastUpdateEnergy = millis();
    unsigned long startTime = millis();
    Volt = pzem.voltage(ip);
    Volt = Volt > 0 ? Volt : 0;
    Amp = pzem.current(ip);
    Amp = Amp > 0 ? Amp : 0;
    Power = Volt * Amp;
    Energy += Power/3600;
    Serial.print("Load time: ");
    Serial.print(millis() - startTime);
    Serial.println("ms");
    Serial.println("Voltage: " + String(Volt, 2));
    Serial.println("Current: " + String(Amp, 2));
    Serial.println("Power: " + String(Power, 2));
    Serial.println("Energy: " + String(Energy));
    Serial.println("--------------------");
  time_t now = time(nullptr);
  struct tm* nowTime = localtime(&now);
  if ((nowTime->tm_sec % 30) == 0) {
    lastUpdateFirebase = millis();
    StaticJsonBuffer<200> jsonBuffer;
    JsonObject& root = jsonBuffer.createObject();
    root["volt"] = Volt;
    root["amp"] = Amp;
    root["time"] = getTime();
    String name = Firebase.push("/logPower", root);
    // handle error
    if (Firebase.failed()) {
      Serial.print("pushing failed:");
      Serial.println(Firebase.error());
      return;
    Serial.print("pushed: /logPower/");
    Serial.println(name);
    Firebase.setInt("/energy", Energy);
      return;
    Firebase.setFloat("/amount", calBill(Energy / 1000, FIX_FT, false));
      return;
  delay(0); // Disable WDT
String getTime() {
  struct tm* newtime = localtime(&now);
  String tmpNow = "";
  tmpNow += String(newtime->tm_year + 1900);
  tmpNow += "-";
  tmpNow += String(newtime->tm_mon + 1);
  tmpNow += "-";
  tmpNow += String(newtime->tm_mday);
  tmpNow += " ";
  tmpNow += String(newtime->tm_hour);
  tmpNow += ":";
  tmpNow += String(newtime->tm_min);
  tmpNow += ":";
  tmpNow += String(newtime->tm_sec);
  return tmpNow;
float calBill(float Unit, float ft, bool over_150_Unit_per_month) {
  float Service = over_150_Unit_per_month ? 38.22 : 8.19;
  float total = 0;
  if (!over_150_Unit_per_month) {
    float Rate15 = 2.3488;
    float Rate25 = 2.9882;
    float Rate35 = 3.2405;
    float Rate100 = 3.6237;
    float Rate150 = 3.7171;
    float Rate400 = 4.2218;
    float RateMore400 = 4.4217;
    if (Unit >= 0) total += min(Unit, 15) * Rate15;
    if (Unit >= 16) total += min(Unit - 15, 10) * Rate25;
    if (Unit >= 26) total += min(Unit - 25, 10) * Rate35;
    if (Unit >= 36) total += min(Unit - 35, 65) * Rate100;
    if (Unit >= 101) total += min(Unit - 100, 50) * Rate150;
    if (Unit >= 151) total += min(Unit - 150, 250) * Rate400;
    if (Unit >= 401) total += (Unit - 400) * RateMore400;
    float Rate150 = 3.2484;
    total += min(Unit, 150) * Rate150;
    if (Unit >= 151) total += min(Unit - 150, 150) * Rate400;
  total += Service;
  total += Unit * (ft / 100);
  total += total * 7 / 100;
  return total;
Your time info retrieval isn't working. 1970 is just default time zero.
INTP:
How can i fix to make it working? so it seems like the problem is from my code?
I just try using other wifi (my cellular) now its working. The time is correct according to my local time. I dont know why changing the wifi can affect the time like that. However, It is neccesery to use the first wifi for my work so the problem is continue...
1970-1-1 at 8.0.30
That's not the start of the Unix timestamp (that should have been midnight). It looks like you pick up some rubbish from incorrect memory locations, maybe because tmpNow goes out of scope as soon as you leave the getTime function?
String getTime() {
  String tmpNow = "";
  return tmpNow;
Note
It's not advisable to use String (capital S); they can leave holes in your memory and as a result you might run out of memory resulting in difficult to find problems.
sterretje:
String getTime() {
String tmpNow = "";
 return tmpNow;
Note
The function returns a copy of the tmpNow string, so that's not the problem.
I bet localtime() is applying a timezone offset of +8 hours.
sterretje:
Note
Much less of a problem with esp8266, which has loads of ram (80K?), than with Uno etc (2K ram). I've monitored free space over extended periods with some of my code that uses String class, and it remained stable after a while. Perhaps there is some simple garbage collection going on, or at least a reasonably good recycling of heap space. I would not recommend using String on Uno either.
