Why do i get this error?
#include <ESP8266WiFi.h>
#include <AdafruitIO.h>
#include <Adafruit_MQTT.h>
#include "Adafruit_MQTT_Client.h"
#include <ArduinoHttpClient.h>
#include "DHTesp.h"
#include <WiFiUdp.h>
#include <NTPClient.h>
#define ON_S1 D1
#define ON_S2 D2
#define FULSLP 21600000
// set up the 'Sensor' feed
AdafruitIO_Feed *S1 = io.feed("S1");
AdafruitIO_Feed *S2 = io.feed("S2");
AdafruitIO_Feed *S3 = io.feed("S3");
//set up the 'Output' feed
AdafruitIO_Feed *PUMP = io.feed("PUMP");
AdafruitIO_Feed *LIGHT = io.feed("LIGHT");
AdafruitIO_Feed *SOLARMODE = io.feed("SOLARMODE");
AdafruitIO_Feed *NIGHTMODE = io.feed("NIGHTMODE");
// set up the 'DHT Sensor'
DHTesp dht;
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "pool.ntp.org", 28800);
int Moist, MoistS, Temp, TempS, Humid, HumidS, PU, LI, SO, NM, SM;
unsigned long lastUpdate, DepSlep;
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);
  pinMode(ON_S1, OUTPUT);
  pinMode(ON_S2, OUTPUT);
  // start the serial connection
  //DHT11 Sensor Setup to GIO 14(D5)
  dht.setup(14, DHTesp::DHT11);
  // connect to io.adafruit.com
  Serial.println("Connecting to Adafruit IO");
  io.connect();
  PUMP->onMessage(handlePump);
  LIGHT->onMessage(handleLight);
  SOLARMODE->onMessage(handleSolarmode);
  NIGHTMODE->onMessage(handleNightmode);
  // wait for a connection
  while (io.status() < AIO_CONNECTED) {
    Serial.print(".");
  timeClient.begin();
  // we are connected
  Serial.println(io.statusText());
  // io.run(); is required for all sketches.
  // it should always be present at the top of your loop
  // function. it keeps the client connected to
  // io.adafruit.com, and processes any incoming data.
  io.run();
  if (millis() > (lastUpdate + 15000)) {
    Moisture();
    S1->save(Moist);
    TemperatureHumidity();
    S2->save(Temp);
    S3->save(Humid);
    timeClient.update();
    Serial.println(timeClient.getFormattedTime());
  if (millis() > (lastUpdate + 1000)) {
    //Time Updates
    //Pump control
    if (PU == 1)
      digitalWrite(ON_S1, HIGH);
    else if (PU == 0)
      digitalWrite(ON_S1, LOW);
    else if (Moist <= 70) {
      while (Moist == 100);
    //Light control
    if (LI == 1)
      digitalWrite(ON_S2, HIGH);
    else if (LI == 0)
    if (timeClient.getHours() <= 0 && timeClient.getHours() >= 6 && NM == 1) {
      DepSlep = FULSLP - (timeClient.getHours() * 60 * 60 * 1000) - (timeClient.getMinutes() * 60 * 1000) - (timeClient.getSeconds() * 1000);
      ESP.deepSleep(DepSlep);
    lastUpdate = millis();
void handlePump(AdafruitIO_Data * data) {
    int PU = data->toInt();
void handleLight(AdafruitIO_Data * data) {
    int LI = data->toInt();
void handleSolarmode(AdafruitIO_Data * data) {
    int SM = data->toInt();
void handleNightmode(AdafruitIO_Data * data) {
    int NM = data->toInt();
void Moisture() {
    //Soil Moisture Sensor
    Moist = analogRead(A0) - 319;
    Moist = 0.142 * Moist;
    Moist = 100 - Moist;
    if (Moist > 100) {
      Moist = 100;
    else if (Moist < 0) {
      Moist = 0;
  void TemperatureHumidity() {
    //Sensor DHT11 Temperature and Humidity
    Temp = dht.getTemperature();
    Humid = dht.getHumidity();
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled, All SSL ciphers (most compatible), 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
D:\w0rK\FYP\FYP_Modification3\FYP_Modification3.ino: In function 'void setup()':
FYP_Modification3:70:19: error: 'handlePump' was not declared in this scope
FYP_Modification3:71:20: error: 'handleLight' was not declared in this scope
FYP_Modification3:72:24: error: 'handleSolarmode' was not declared in this scope
FYP_Modification3:73:24: error: 'handleNightmode' was not declared in this scope
D:\w0rK\FYP\FYP_Modification3\FYP_Modification3.ino: In function 'void loop()':
FYP_Modification3:97:14: error: 'Moisture' was not declared in this scope
     Moisture();
FYP_Modification3:100:25: error: 'TemperatureHumidity' was not declared in this scope
FYP_Modification3:144:41: error: a function-definition is not allowed here before '{' token
FYP_Modification3:148:42: error: a function-definition is not allowed here before '{' token
FYP_Modification3:152:46: error: a function-definition is not allowed here before '{' token
FYP_Modification3:156:46: error: a function-definition is not allowed here before '{' token
FYP_Modification3:160:17: error: a function-definition is not allowed here before '{' token
 void Moisture() {
FYP_Modification3:177:3: error: expected '}' at end of input
exit status 1
option enabled in File -> Preferences.
Loop is missing a closing }
yeah i see it thx for helping
