Hi.
This is a very lame question. I tried posting to the sensor forum but there isn't a single reply there! This is my first Arduino and the problem is that whenever I start communication with the board I seem to kill it - I need to push the rest button to get the program running. I'm reading input from a MaxSonar US sensor (EZ1 MB1210) and the code I'm using is simply:
//Digital pin 7 for reading in the pulse width from the MaxSonar device.
//This variable is a constant because the pin will not change throughout execution of this code.
const int pwPin = 7;
//variables needed to store values
long pulse, cm;
//This opens up a serial connection to shoot the results back to the PC console
//Set up the input pin.
pinMode(pwPin, INPUT);
//Used to read in the pulse that is being sent by the MaxSonar device.
//Pulse Width representation with a scale factor of 58uS per centimetre.
pulse = pulseIn(pwPin, HIGH);
//58uS per cm
cm = pulse/58;
Serial.println(cm);
delay(10);
Every time I try to read it (in Director through the Serial Xtra) I need to push the reset button on the Arduino to start the on-board program to start passing out readings. Why? Do I need to prep the sensor somehow in the setup()?
Apologies for the lameness but any advice is really appreciated. Thanks.
