This was asked in Nov '17 but no answer was given. So my code is
#include "Adafruit_VL53L0X.h"
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
long timeLast = 0;
long timeNow = 0;
long timeGap = 0;
float timeN = 0;
// wait until serial port opens for native USB devices
while (! Serial) {
delay(1);
Serial.println("Adafruit VL53L0X test.");
if (!lox.begin()) {
Serial.println(F("Failed to boot VL53L0X"));
while(1);
// power
Serial.println(F("VL53L0X API Continuous Ranging example\n\n"));
// start continuous ranging
lox.startRangeContinuous();
if (lox.isRangeComplete()) {
timeNow = micros();
timeN = micros();
timeGap = timeNow - timeLast;
Serial.print(timeNow);
Serial.print(",");
Serial.print(lox.readRange());
Serial.print(",");
Serial.print(timeGap);
Serial.print(",");
Serial.println(timeN);
timeLast = timeNow;
I am running it on a Uno R3 board. When I check the output by subtracting timeNow from timeN, I find occasionaly I get a value of -4, that is time according to the two calls of the micros function has gone backwards. If I switch timeN to a data type long, I don't get negative values. Fortunately, I intend to put some code between the two micros calls which also ensures I don't get negative values.
So whilst I don't need a cure, I thought it might be worth flagging up the curious behaviour. Some one suggested it might be hardware related. I do have not only the VL53LOX sensor attached but also a shield with an SD card and clock.
