Hi, I’ve been trying to understand Serial and tried to follow this code for creating a buffer for data coming in through Serial: Gammon Forum : Electronics : Microprocessors : How to process incoming serial data without blocking
I understand it’s kind of old but it seems the sketch doesn’t use anything that’s deprecated so I still tried to follow it.
My question is, within the sketch itself it does a while loop when data is available:
// if serial data available, process it
while (Serial.available () > 0)
processIncomingByte (Serial.read ());
// do other stuff here like testing digital input (button presses) ...
} // end of loop
and calls the processIncomingByte() function taking the data from the Serial using Serial.read() as an argument. The function takes each character from the data as a byte and stores it in a character array using switch statements to determine when it stops storing (when ‘\n’ is detected). What I don’t understand is this:
void processIncomingByte (const byte inByte)
static char input_line [MAX_INPUT];
static unsigned int input_pos = 0;
switch (inByte)
case '\n': // end of text
input_line [input_pos] = 0; // terminating null byte
// terminator reached! process input_line here ...
process_data (input_line);
// reset buffer for next time
input_pos = 0;
case '\r': // discard carriage return
default:
// keep adding if not full ... allow for terminating null byte
if (input_pos < (MAX_INPUT - 1))
input_line [input_pos++] = inByte;
} // end of switch
} // end of processIncomingByte
Inside the processIncomingByte() function, it initializes the static unsigned integer variable “input_pos” to 0.
Why does it not reset after every while loop instance that “Serial.read()” is made if it is initialized over and over again per character of the input data?
why does the while loop not have “{ }” in the sketch as well?
how does a Byte of data can directly be stored in a char array? Shouldn’t it be converted first?
I tried to get the raw data of any incoming input data I put in through the Serial monitor by Serial.print() but it always comes out as the ASCII representation. Is there a way to print the RAW bits of the characters I send?
I tried to understand it by placing a Serial.write() to provide data but it seems Serial.read() does not recognize it. Why is writing data through Serial.write() not work?
Note: If I misunderstood anything about how the sketch works, any comments would be much appreciated. Thank you!
