Hello,
I am trying to establlish HC-12 link between two Arduino Nano Every. The Nano is currently is fed from the USB, while the HC-12 is fed from the Nano 3.3V output (with bypass tantalum 22uF cap). Its consuption is a little more than 50mA' well within the Nano capabilities.
The sketch contains currently only the SETUP method, that sends also some AT commands using HC-12 standard library (https://github.com/PowerBroker2/SerialTransfer).
When I connect loopback across the TX1-RX1 and print the received text - all is good. However, as soon as I connect the RX and TX line (the SET line is grounded in this test configuration) I start reading 4.52V on +5V output, RX1 and TX1 and the l\HC-12 does not respond. The 4.52V remains after disconnecting the TX1 and RX1 lines. In spite the high voltage, the loopback TX1-RX1 works. The same happens on two sets of components.
The 3.3V output is exact if the HC-12 is connected or disconnect, meaning the on-board regulator is not loaded.
Serial.begin();
Serial.println("Init started");
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, false);
Comm.begin();
Serial1.println("");
Serial.println ("transmitted");
delay(20);
if(Serial1.available())
Serial.println(Serial1.read());
HC-12.h
#ifndef hc12_h
#define hc12_h
#include "src\radio\SerialTransfer.h"
class comm {
public:
uint16_t machineStationRx();
uint16_t txData(const String &txStr);
String remoteControllerTxRx(uint16_t txCommand);
void begin();
const uint16_t rxMmachineStationError = 0xffff;
bool stationType; // low - machine, high - remote control mode
uint8_t available () {return myTransfer.available(); };
private:
#define comVerbose
#define txRxPin 15 // MPU D15
#define hc12Mode 16 // MPU D16
#define txDelay 500
#define txInterval 1000
#define txPower '3'
SerialTransfer myTransfer;
long intervalCounter;
uint16_t rxBuffer[4];
uint16_t msgCount = 1;
uint16_t previousPacketCounter;
#endif
HC-12.cpp
#include "HC12.h"
uint16_t comm::txData (const String &txStr)
uint16_t sendSize = 0;
sendSize = myTransfer.txObj(txStr.c_str());
return myTransfer.sendData(sendSize);
void comm::begin() {
Serial1.begin(9600);
while (!Serial1)
; // Before actually need the serial ports
pinMode(txRxPin, INPUT_PULLUP);
stationType = digitalRead(txRxPin);
pinMode(hc12Mode, OUTPUT);
digitalWrite(hc12Mode, false); // Set commands mode
intervalCounter = millis();
configST setUpConfig;
setUpConfig.debug = false;
setUpConfig.callbacksLen = 0;
myTransfer.begin(Serial1, setUpConfig);
bool hc12error = false;
uint16_t txLen = txData("AT+P" + txPower);
delay(10);
String rxMsg = "";
uint16_t rxLen = 0;
Serial.print("TX power reply = (1)"); // For debug
Serial.print(String(rxMsg) + " (2) "); // For debug
rxLen = myTransfer.rxObj(rxMsg, rxLen);
Serial.print(String(rxMsg + " (3) ")); // For debug
Serial.print(String(rxMsg)); // For debug
Serial.println(); // For debug
char rep[] = { 'O', 'K', '+', 'P', txPower };
hc12error |= (rxLen != sizeof(rep)) | (rxMsg != rep);
//#ifdef comVerbose
Serial.println(String(rxMsg));
//#endif
txLen = txData("AT+B9600");
delay(10);
rxLen = myTransfer.rxObj(rxMsg, 0, txLen);
char rep1[] = "OK+B9600";
hc12error |= (rxMsg != rep1);
//#ifdef comVerbose
Serial.print("Baud rate reply = ");
//#endif
myTransfer.reset();
digitalWrite(hc12Mode, true); // Set transmission mode
previousPacketCounter = 0;
uint16_t comm::machineStationRx() {
uint8_t recSize = 0;
recSize = myTransfer.rxObj(rxBuffer, 0, recSize);
#ifdef comVerbose
Serial.println("First reception len=" + String(recSize) + "\nbuffer[0], [1]m [2], counter" + String(rxBuffer[0], HEX) + "/" + String(rxBuffer[1], HEX) + "/" + String(rxBuffer[2], HEX) + "/" + String(rxBuffer[3], HEX));
#endif
uint16_t tempMsgId = rxMmachineStationError;
previousPacketCounter = rxBuffer[3];
// Verify that the message counter is either the the previous message; one skipped message is allowed.
if ((rxBuffer[3] != tempMsgId - 2) && (rxBuffer[3] != tempMsgId - 1))
return rxMmachineStationError;
myTransfer.reset();
// Voting - 2 items out of 3 should be equal
if ((rxBuffer[0] != rxBuffer[1]) && (rxBuffer[0] != rxBuffer[2])) {
if (rxBuffer[1] == rxBuffer[2])
return rxBuffer[1];
return rxBuffer[0];
String comm::remoteControllerTxRx(uint16_t txCommand) {
// txPackageId++;
if ((millis() - intervalCounter) < txInterval)
return "";
String txBuffer = String(txCommand, HEX);
txBuffer += txBuffer + txBuffer + String(msgCount++, HEX);
uint16_t i = txData(txBuffer);
if(i != txBuffer.length())
return "?S tx error";
long txTimer = millis();
while (!myTransfer.available() && ((millis() - txTimer) < txDelay))
if (!myTransfer.available()) // Analyze loop exit condition
return "Communication loop timeout";
String receiveData;
recSize = myTransfer.rxObj(receiveData, recSize);
if (recSize == 0)
return "Communication package length error";
return receiveData;
