Dear Arduino community,
I am new to Arduino and learning the hardware and software, recently I made a clock with Arduino Nano, DS1307 and SSD1306 display using standard Wire, RTC1307, Time and U8glib. Although the display and DS1307 work flawlessly, however, when I added the button code the clock display starts at 30 seconds and then resets to 30 seconds again when it reaches 59 seconds. The code is mentioned below, and I would appreciate if experts here could suggest how to fix it.
#include "U8glib.h" // OLED
#include <Wire.h> // I2C
#include "Time.h" // Time Manipulation
#include "DS1307RTC.h" // DS1307 RTC
#define DS1307_ADDRESS 0x68
byte zero = 0x00; //workaround for issue #527
char timebuf[10]; // Time
char datebuf[10]; // Date
int year2digit; // 2 digit year
int year4digit; // 4 digit year
const int buttonPin = 3; // the number of the pushbutton pin
int buttonState = 0; // variable for reading the pushbutton status
void setDateTime(){
byte second = 30; //0-59
byte minute = 35; //0-59
byte hour = 19; //0-23
byte weekDay = 2; //1-7
byte monthDay = 16; //1-31
byte month = 8; //1-12
byte year = 16; //0-99
Wire.beginTransmission(DS1307_ADDRESS);
Wire.write(zero); //stop Oscillator
Wire.write(decToBcd(second));
Wire.write(decToBcd(minute));
Wire.write(decToBcd(hour));
Wire.write(decToBcd(weekDay));
Wire.write(decToBcd(monthDay));
Wire.write(decToBcd(month));
Wire.write(decToBcd(year));
Wire.write(zero); //start
Wire.endTransmission();
byte decToBcd(byte val){
return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val) {
return ( (val/16*10) + (val%16) );
//U8GLIB_SH1106_128X64 u8g(13, 11, 10, 9, 8); // D0=13, D1=11, CS=10, DC=9, Reset=8
U8GLIB_SSD1306_128X64 u8g(10, 9); // MRA's Settings
void draw(void) {
u8g.setFont(u8g_font_fur11); // select font
u8g.setPrintPos(5, 30); // set position for displaying time
u8g.print(timebuf); // display time
u8g.setPrintPos(5, 55); // set position for displaying date
u8g.print(datebuf); // display date
void print2digits(int number) {
if (number >= 0 && number < 10) {
Serial.write('0');
Serial.print(number);
void setup(void) {
pinMode(buttonPin, INPUT);
while (!Serial) ;
delay(200);
Serial.println("DS1307RTC Read Test");
Serial.println("-------------------");
void loop(void) {
tmElements_t tm;
if (RTC.read(tm)) {
year2digit = tm.Year - 30; // 2 digit year variable
Serial.print("Ok, Time = ");
print2digits(tm.Hour);
Serial.write(':');
print2digits(tm.Minute);
Serial.write(':');
print2digits(tm.Second);
Serial.print(", Date (D/M/Y) = ");
Serial.print(tm.Day);
Serial.write('/');
Serial.print(tm.Month);
Serial.write('/');
Serial.print(tmYearToCalendar(tm.Year));
sprintf(timebuf, "%02d:%02d:%02d",tm.Hour, tm.Minute, tm.Second); // format time
sprintf(datebuf, "%02d/%02d/%02d",tm.Day, tm.Month, year2digit); // format date
u8g.firstPage(); // Put information on OLED
do {
draw();
} while( u8g.nextPage() );
else {
if (RTC.chipPresent()) {
Serial.println("The DS1307 is stopped. Please run the SetTime");
Serial.println("example to initialize the time and begin running.");
Serial.println("DS1307 read error! Please check the circuitry.");
delay(9000); // Delay of 1sec
buttonState = digitalRead(buttonPin);
if (buttonState == LOW) {
setDateTime();
} else {buttonState==HIGH;
When I un-check this code from the loop the clock resets.
setDateTime();
