I am relatively new to the Arduino scene and have gone through most of the tutorials that i have the kit to do but i require a bit of help on a small project for the wife.
We are looking at re-purposing an obsolete printer to cutour rolls of vinyl to more manageable sizes, the printer is stripped down to the parts I need, Motors, Encoders, Feed and Cut systems.
I have a Arduino Mega 2650 to control my project via a L298 Dual H-Bridge and can successfully control the motors and positioning via the encoders using a sketch on the Homofacians website. I have adapted this to run 2 motors and encoders including moving the pins about to allow the use of the interupt pins 2-5. However i am struggling to work the code to run a sequence to allow the system to run autonomously.
The sequence would look like this:
- Feed Roller (x axis) feeds out 36600 steps (297mm in real measurements)
- Once (x axis) reaches position the cutter (y axis) runs full width of 6600 steps (1500mm)
- This will run for a set amount of times
I can run the feed out to the correct distance and also throw the cutter in both directions(including adapting the code to run the cutter from a single button in both directions, however if I try to sequence them they either feed and cut together or only do 1 of the 2 actions, I have tried "IF, IF..ELSE, WHILE, DO..WHILE, DELAY and MILLIS"
This is a snippet of the code that i used to run the motors:
void loop() { // main program
unsigned long currentTime = millis();
xdutyCycle = (double)(abs(xsetPoint - xactualPoint)) * (double)P_FRACTION;
ydutyCycle = (double)(abs(ysetPoint - yactualPoint)) * (double)P_FRACTION;
// possibly look at map and constrain next 4 if loops.
if (xdutyCycle < MIN_XDUTYCYCLE) { // x min constrain
xdutyCycle = MIN_XDUTYCYCLE;
if (xdutyCycle > MAX_XDUTYCYCLE) { // x max constrain
xdutyCycle = MAX_XDUTYCYCLE;
if (ydutyCycle < MIN_YDUTYCYCLE) { // y min constrain
ydutyCycle = MIN_YDUTYCYCLE;
if (ydutyCycle > MAX_YDUTYCYCLE) { // y min constrain
ydutyCycle = MAX_YDUTYCYCLE;
// end of poss map & constrain
if (abs(xsetPoint - xactualPoint) < XSTEP_MARGIN) { // x axis no movement
analogWrite(XMOTOR_PWM, 0);
digitalWrite(XMOTOR_DIRECTION, 0);
else {
if (xactualPoint < xsetPoint) { // x axis Fwd movement Feed Out
digitalWrite(XMOTOR_DIRECTION, 1);
analogWrite(XMOTOR_PWM, 255 - xdutyCycle);
if (xactualPoint > xsetPoint) { // x axis Rev movement Feed In
analogWrite(XMOTOR_PWM, xdutyCycle);
if (abs(ysetPoint - yactualPoint) < YSTEP_MARGIN) { // y axis no movement
analogWrite(YMOTOR_PWM, 0);
digitalWrite(YMOTOR_DIRECTION, 0);
else {
if (yactualPoint < ysetPoint) { // y axis Fwd movement Cut to Left
digitalWrite(YMOTOR_DIRECTION, 1);
analogWrite(YMOTOR_PWM, 255 - ydutyCycle);
if (yactualPoint > ysetPoint) { // x axis Fwd movement Cut to Right
analogWrite(YMOTOR_PWM, ydutyCycle);
xDiff = (xsetPoint - xactualPoint - XSTEP_MARGIN);
readByte = 0; // serial input set to nul
if (Serial.available() > 0) { //if we get a valid byte, read from serial: used for serial controll
//get incoming byte:
readByte = Serial.read();
//Serial.println('r'); // send a 'r' to initiate next data from computer
if (readByte > 0) { // read serial input
if (readByte == '0') {
//for ( int i=0; i<5; i++ ) {
FeedL();
if (xDiff <= XSTEP_MARGIN){
CutL();
//xactualPoint = 0;
//previousTime = currentTime;
//Serial.println (previousTime);
//Serial.println (currentTime);
/*do
xsetPoint += 36600;
}while (xactualPoint != (xsetPoint - XSTEP_MARGIN));
//xsetPoint++;
CutL();*/
/*xsetPoint += 36600;
delay(3000);
CutL();*/
/*if (xactualPoint >= (xsetPoint - XSTEP_MARGIN)) {
CutL();
} else if (xsetPoint < 36600) {
xsetPoint++;
CutL();
if (readByte == '9') { // cut any way
if (yactualPoint < 3300) {
CutL();
CutR();
if (readByte == 'h') { // y 10
yactualPoint = 0;
ysetPoint = 0;
Serial.println("Cut Home Set!!");
if (readByte == '4') { //A4 Portrait feedout (36600)
xsetPoint += 36600;
if (readByte == '3') { // feed in
xsetPoint -= 36600;
if (readByte == '2') { //A4 Landscape feed out (25700)
FeedL();
if (readByte == '1') { // feed in
xsetPoint -= 25700;
void FeedL() {
xactualPoint = 0;
xsetPoint = 25700;
void FeedP() {
xactualPoint = 0;
xsetPoint = 36600;
void FeedL_delay() {
delay(3000);
void CutL() {
ysetPoint = 6600;
void CutR() {
ysetPoint = 5;
Due to the forum limitations and size of the code i have attached the full .ino file that i am currently working from, I know it is bloated with bits that are not needed or could be simplified with library's such as encoder.h.
Currently this all runs from the serial monitor but when I can nail the problem swapping to buttons on the front panel wont be such a drama.
As you can see i have lined out the codes i have tried but I am quickly loosing hair and sanity as i know its something simple that I am overlooking. Maybe just a fresh set of eyes will be able to point out he errors.
Any help or guidance on this sketch will be gratefully appreciated.
Regards
Smiler
cut_func_working.ino (8.97 KB)
