why does it seam to ignore a comparison - can not figure it out..
hi there i can not figure it out why it ignoring a comparison event
but the section i am having problem with is here :
if( kw < 0){
  Serial.println(" kw  less than zero ");
     if (l1 > 1);{
       level=255;
       rlevel=0;
        Serial.println("  <   level low condition 1  ");
      if (l1 < 1);{
        Serial.println("  < level low  condition 2 ");
        level= (255-level)*stp;
        rlevel=(255-level);
}else{
  Serial.println("kw  greater than zero ");
       if(l1 < 1);{
        rlevel= (255-level)*stp;
         level=(255-rlevel);
          Serial.println("   > level high condition 1 ");
     if(l1 > 1);{
         rlevel = 255;
         level = 0;
         Serial.println("   > level high condition 2 ");
debug value :
This just in … 4E 40 73 5E 1 DC 8C 96 4 EE
level value 0
kw value -1.44
stp value 2.23
l1 value 2.23 -----------------> i have a condition where l1 is greater then
kw less than zero
< level low condition 1 ------------------>seams to step through both conditions
Hchannel 0 --------------------> it should of change the value to 255
Hchannel6 255--------------------> it should of changed to value of 0
level 0
rlevel 255
This just in … 4E 9A DB A7 FE A3 3F 97 3 6B
level value 0
kw value 1.42
stp value 2.53
l1 value 2.53
level high condition 1 ---------------> also seams to step through both conditions
lchannel 0 ---------------------------------> but seams to provide the correct answer
lchannel6 255
level 0
rlevel 255
const byte numBytes = 32;
const int slaveSelectPin = 10;
EnergyMonitor emon1;
byte receivedBytes[numBytes];
byte numReceived = 0;
int cnt = 0;
float kw = 0;
float volts = 124;
float stp = 255;
float inverter = 1;
float kw1 =0;
float le=127;         // level saved condition
int rl1=127; // rlevel saved condtion
int level=127;    // main pot  control for PWM
int rlevel=127;    // if you need reverse pot  direction of PWM
#include <stdio.h>
#include <Wire.h>
#include <SPI.h>
#include <EmonLib.h>
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
int cnt = 0;
float kw = 0;
float volts = 124;
float stp = 255;
float inverter = 1;
float kw1 =0;
boolean newData = false;
    Serial.begin(1200);
    Serial.println("<Arduino is ready>");
   // Serial.begin(1200);
    lcd.begin();
     pinMode(slaveSelectPin, OUTPUT);
      SPI.begin();
  //emon1.voltage(2, 234.26, 1.7);
      // Voltage:input pin, calibration,phase_shift
  emon1.current(1, 111.1);
       // Current: input pin, calibration.
    recvBytesWithStartEndMarkers();
    showNewData();
 //   output();
  //  potset();
void recvBytesWithStartEndMarkers() {
    static boolean recvInProgress = false;
    static byte ndx = 0;
    byte startMarker = 0xAA;
    byte endMarker = 0xAA;
    byte rb;
    while (Serial.available() > 0 && newData == false) {
        rb = Serial.read();
        if (recvInProgress == true) {
            if (rb != endMarker) {
                receivedBytes[ndx] = rb;
                ndx++;
                cnt = ndx;
                if (ndx >= numBytes) {
                    ndx = numBytes - 1;
            else {
                receivedBytes[ndx] = '\0'; // terminate the string
                numReceived = ndx;  // save the number for use when printing
                ndx = 0;
                newData = true;
        else if (rb == startMarker) {
            recvInProgress = true;
void showNewData() {
    if (newData == true) {
        Serial.print("This just in ... ");
        for (byte n = 0; n < numReceived; n++) {
            Serial.print(receivedBytes[n], HEX);
            Serial.print(' ');
        showGroupsOfBytes();
        newData = false;
void showGroupsOfBytes() {
    if ( receivedBytes[0]==0x4E )  {  // change this to match your MTU it - it will display in serial print
     if (cnt == 10) {
    byte j = ~receivedBytes[6];
    byte k = ~receivedBytes[7];
    byte m = ~receivedBytes[3];
    byte r = ~receivedBytes[4];
double voltage = 0;
double power = 0;
voltage = ( k<< 8) | j;
voltage= (123.6 + (voltage - 27620) / 85 * 0.4);
      volts=voltage;
 power = (r<<8) + m;
 power = 1.19 + 0.84 * ((power - 288) / 204);
     kw = power;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("volts ");
    lcd.print(voltage);
    lcd.setCursor(1,1);
    lcd.print("kw ");
    lcd.print(power);
    cnt = 0;
 double Irms = emon1.calcIrms(1480);  // Calculate Irms only
 /* emon1.calcVI(20,2000);
       // Calculate all. No.of half wavelengths (crossings), time-out
  emon1.serialprint();
      // Print out all variables (realpower, apparent power,
      // Vrms,Irms, power factor)
  //float realPower       = emon1.realPower;
         //extract Real Power into variable
 // float apparentPower   = emon1.apparentPower;
         //extract Apparent Power into variable
  //float powerFActor     = emon1.powerFactor;
         //extract Power Factor into Variable
  float supplyVoltage   = emon1.Vrms;
         //extract Vrms into Variable
  float Irms            = emon1.Irms;
   */      //extract Irms into Variable
  inverter = ((Irms*volts)/1000);  // calculates GTI output
Serial.print(" level value  ");
Serial.println(level);
Serial.print("kw value  ");
Serial.println(kw);
stp = (inverter / kw);
stp = abs(stp);
Serial.print(" stp value  ");
Serial.println(stp);
le=((255-level)/255)*stp;
//l1=abs(l1);
Serial.print(" l1 value  ");
Serial.println(le);
if( kw < 0){
     if (le > 1);{
       level=255;
       rlevel=0;
        } //else{
      if (le < 1);{
        rlevel=(255-level);
}else{
       if(le < 1);{
         level=(255-rlevel);
     if(le > 1);{
         rlevel = 255;
         level = 0;
         }//else{
if(kw < 0){
    for (int scan = 0; scan < 1 ; scan++) {
    digitalPotWrite(1, level);
        Serial.print("Hchannel ");
     // delay(10);
    digitalPotWrite(2, level);
  //      Serial.println("Hchanne2");
   // Serial.println(level);
  //  Serial.println(2);
      //delay(10);
    digitalPotWrite(3, level);
   //     Serial.println("Hchanne3");
   // Serial.println(3);
      //delay(10);
    digitalPotWrite(4, rlevel);
    //    Serial.println("Hchanne4");
   // Serial.println(rlevel);
    //Serial.println(4);
      //delay(10);
    digitalPotWrite(5, rlevel);
  //      Serial.println("Hchanne5");
  //  Serial.println(5);
      //delay(10);
    digitalPotWrite(6, rlevel);
    Serial.print("Hchannel6 ");
   // Serial.println(Irms);
    //level=level+1;
      //delay(10);
 if(kw>0)
  //if(level>=0)
   for (int scan = 0; scan < 1; scan++) {
        Serial.print("lchannel ");
     // delay(10);
    //    Serial.println("lchanne2");
      //delay(10);
  //      Serial.println("lchanne3");
      //delay(10);
   //     Serial.println("lchanne4");
  //  Serial.println(4);
     // delay(10);
   //     Serial.println("lchanne5");
     // delay(10);
    Serial.print("lchannel6  ");
    //Serial.println(Irms);
   // level=level-1;
     Serial.print("level ");
     Serial.print("rlevel ");
      Serial.println(" ");
void digitalPotWrite(int address, int value) {
  // take the SS pin low to select the chip:
  digitalWrite(slaveSelectPin, LOW);
  //  send in the address and value via SPI:
  SPI.transfer(address);
  SPI.transfer(value);
  // take the SS pin high to de-select the chip:
 digitalWrite(slaveSelectPin, HIGH);
if (l1 > 1);
BONG !
What's that semicolon doing there ?
Also, given this code:
    static boolean recvInProgress = false;    // <--- Given this....
    byte rb;
        rb = Serial.read();
        if (recvInProgress == true) {         // ...how does this happen?
How does recvInProgress ever get set to true?
Edit: I see the set for recvInProgress, so are you assuming that Serial is not available when the function is entered?
thanks UKheliBob - i rewote it so many times that section and i keep missing that over and over again well there went 8 hrs of wasted time... DUH!!!
econjack _ never wrote that piece of code I just sampled it from a tutorial on the arduino fourum.. but it working and it captures the bytes to where I can work with them.. but it set the to true several lines down from there
else if (rb == startMarker) { recvInProgress = true;
econjack: Edit: I see the set for recvInProgress, so are you assuming that Serial is not available when the function is entered?
I believe he is using code from Serial Input Basics
...R
Congratulation on using Serial to debug your code.
It would be more useful, especially in this case of “if(tue) do not’ing;” code error ( don’t feel bad it is easy to make such error) if you actually printed the “I1” value.
BTW using single letter for variable name is another source of bugs, use “long hand” and meaningful name.
Good luck.
       if(l1 < 1);{
         level=(255-rlevel);
     if(l1 > 1);{
         rlevel = 255;
         level = 0;
