Why does it takes several presses for my LED to light?
Button1 is the problem here.
// set pins
const int buttonPin1 = 2;                 // Pin1's pushbutton
const int buttonPin2 = 4;                 // Pin2's pushbutton
const int buttonPin3 = 6;                 // Pin3's pushbutton
const int buttonPin4 = 8;                 // Pin4's pushbutton
const int ledPin1 = 3;                    // Pin1's LED
const int ledPin2 = 5;                    // Pin2's LED
const int ledPin3 = 7;                    // Pin3's LED
const int ledPin4 = 9;                    // Pin4's LED
// set variables
int ledPin1_status = 0;
int ledPin2_status = 0;
int ledPin3_status = 0;
int ledPin4_status = 0;
void setup() {  //initialize pins
 pinMode(buttonPin1, INPUT); // set PINn as INPUT
 pinMode(buttonPin2, INPUT);
 pinMode(buttonPin3, INPUT);
 pinMode(buttonPin4, INPUT);
 pinMode(ledPin1, OUTPUT);   // set LEDn as OUTPUT
 pinMode(ledPin2, OUTPUT);
 pinMode(ledPin3, OUTPUT);
 pinMode(ledPin4, OUTPUT);
// the following variables are unsigned longs because the time, measured in
// milliseconds, will quickly become a bigger number than can be stored in an int.
unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
unsigned long debounceDelay = 50;    // the debounce time; increase if the output flickers
 if (digitalRead(buttonPin1) == HIGH) { // check if buttonPin1 was pressed (be sure to use a resistor?)
   if (ledPin1_status == 0) {           // check if ledPin1 was not already pressed
     digitalWrite(ledPin1, HIGH);       // turn ledPin1 on
     ledPin1_status = 1;                // 1 = on, set ledPin1_status to 1
   else {
     digitalWrite(ledPin1, LOW);        // turn ledPin1 off
     ledPin1_status = 0;                // 0 = off, set Pin1_status to 0
     digitalWrite(ledPin2, LOW);        // turn ledPin2 off
     ledPin2_status = 0;                // 0 = off, set Pin2_status to 0
     digitalWrite(ledPin3, LOW);        // turn ledPin3 off
     ledPin3_status = 0;                // 0 = off, set Pin2_status to 0
     digitalWrite(ledPin4, LOW);        // turn ledPin4 off
 if (digitalRead(buttonPin2) == HIGH) { // check if buttonPin2 was pressed (be sure to use a resistor?)
   {digitalWrite(ledPin2, HIGH);       // turn ledPin2 on
     ledPin2_status = 1;                // 1 = on, set ledPin2_status to 1
    {digitalWrite(ledPin2, LOW);       // turn ledPin2 on
 if (digitalRead(buttonPin3) == HIGH) { // check if buttonPin3 was pressed (be sure to use a resistor?)
   {digitalWrite(ledPin3, HIGH);       // turn ledPin3 on
     ledPin3_status = 1;                // 1 = on, set ledPin3_status to 1
if (digitalRead(buttonPin3) == HIGH) { // check if buttonPin2 was pressed (be sure to use a resistor?)
    {digitalWrite(ledPin3, LOW);       // turn ledPin3 on
if (digitalRead(buttonPin4) == HIGH) { // check if buttonPin2 was pressed (be sure to use a resistor?)
   {digitalWrite(ledPin4, HIGH);       // turn ledPin4 on
    {digitalWrite(ledPin4, LOW);       // turn ledPin4 on
Come on, we need a bit more to go on. Do the other buttons work and it's just #1 that is a problem?
How are the buttons wired? Have you heard of INPUT_PULLUP?
Seems to be a continuation of
which was in turn a follow on from
It would be a lot easier if you kept your questions about the one sketch in one thread.
Steve
