Why does LED3 not fire up?
Hi
i have a problem with my code. yeah, i know, i could have used an array instead and what not. but i'm new to coding and my language skills are not strong :slight_smile:
trying to make a button, with which i can cicly through different outputs. at the end there should be a relay on each output, to switch different lights (230V / europe) in the house.
so, my problem is this: i have a counter which works fine. it counts from 1 to 3. the leds (relays) fire up when the mode is in the right state - all but the LED3!
i just cannot see the error...
the other two are working and when the counter is back on 1 again, it works again. its just the third LED, which is not lighing up (the counter goes on 3 dough)
what could be the problem?
//VAR
int mode = 0;
//BUTTON
int buttonPin = 2;
//LED
int ledPin_1 = 5;
int ledPin_2 = 6;
int ledPin_3 = 9;
  pinMode (buttonPin, INPUT);
  pinMode (ledPin_1, OUTPUT);
  pinMode (ledPin_2, OUTPUT);
  pinMode (ledPin_3, OUTPUT);
  //monitoring
  while (digitalRead(buttonPin) == LOW) {
    mode++;
    Serial.println(mode);
    if (mode >= 3){
      (mode = 0);
if (mode == 1){
  digitalWrite(ledPin_2, LOW);
  digitalWrite(ledPin_3, LOW);
  digitalWrite(ledPin_1, HIGH);
if (mode == 2){
  digitalWrite(ledPin_1, LOW);
  digitalWrite(ledPin_2, HIGH);
if (mode == 3){
  digitalWrite(ledPin_3, HIGH);
Have you swapped LEDs around to check if you have a dud LED or one the wrong way around.
Checked the arduino output with a DMM?
Tom... :slight_smile:
Your mode variable cycles through 0, 1, 2 then back to 0.
Your if statements are checking for modes 1, 2 or 3.
 mode++;
if (mode >= 3)
This says if mode is greater than or EQUAL to 3, then mode = 0.
So you make mode =3 then immediately make it 0.
 mode++;
if (mode > 3)
Will let mode =3 for the cycle of the loop.
@tom, yeah i have swapped the leds and assigned to new pins. but i didn't check if them with a DMM.
@gypsum, thank you for this input. didn't thought about that. i assigned the statements no to 0,1,2. it works now
however, it has a funny behave to it.
  • The Mode is 0 if i start the arduino.
  • then when i click the button its: 1,2,3 - and back to one (because "if (mode >= 3){
    (mode = 0);")
when i start up the arduino, LED1 is ON, because mode = 0.
after that first cycle, LED1 is on at Mode 3!
i can't wrap that around my head. can you explain me the logic behind it?
is the arduino like: "ah, it is not mode2 or 1, so everything else is equal to 0!"
or how does this work?
EDIT:
alright tom, thank you! i think i get it now... slowely:)
its just hard to understand because the serial monitor prints 1,2,3 all the time, although the mode is 0 sometimes..!
next step, implement a RTC, phuu...:slight_smile:
i have a following question.
when i press the button, it cycles thru all modes (with the delay of 500ms)
how can i make it just an impulse?
so that it only steps 1 mode up, even if the button stays pressed.
cheers
Look at the StateChangeDetection example in the IDE
UKHeliBob:
thank you for the fast answer!
