I am currently engaged in the development of a bioreactor for cultivating algae. However, I have encountered an issue where my 24-hour loop is not functioning as intended. Despite my efforts to diagnose the problem, I have been unable to identify the root cause after days of investigation. Would you be so kind as to lend your expertise and examine the bioreactor code ? Your assistance would be greatly appreciated and hold significant value to me.
Situation sketch
Please accept my apologies for not having provided a clear explanation of the situation from the outset. To clarify, the following sequence of events occurred:
- The code was successfully uploaded to the Arduino.
- The Arduino was disconnected from the PC after being plugged in to the wall.
- For approximately five hours, the code operated without issue.
- The code ceased functioning correctly at a certain point, specifically after executing the next piece of code.
if (Teltijd - Starttijd1 >= 25200000 && Teltijd - Starttijd1 <= 39600000) { - At this juncture, the Arduino ceased functioning properly and for instance, the LED panel and pump stay on.
#include <EEPROM.h>
#include <Arduino.h>
template <class T> int EEPROM_writeAnything(int ee, const T& value) {
const byte* p = (const byte*)(const void*)&value;
unsigned int i;
for (i = 0; i < sizeof(value); i++)
EEPROM.write(ee++, *p++);
return i;
const unsigned long DayIntterval = 86400000;
const unsigned long AlgenMeetingInterval = 1800000;
const unsigned long PompjeIntervalNacht = 3600000;
const unsigned long RustInterval = 7200000;
unsigned long Starttijd1 = 0;
unsigned long Starttijd2 = 0;
unsigned long Starttijd3 = 0;
unsigned long Starttijd4 = 0;
int RelayLedPanel = 7;
int RelayAirPump = 6;
int AlgaeConcentrationIndicator = 2;
int LDR1 = A0;
int LDR2 = A1;
int LDR3 = A2;
int addr = 0;
float versturen;
pinMode(AlgaeConcentrationIndicator, OUTPUT);
pinMode(RelayAirPump, OUTPUT);
pinMode(RelayLedPanel, OUTPUT);
pinMode(LDR1, INPUT);
pinMode(LDR2, INPUT);
pinMode(LDR3, INPUT);
digitalWrite(RelayLedPanel, LOW);
delay(2000);
digitalWrite(RelayLedPanel, HIGH);
delay(2000);
unsigned long Teltijd = millis();
if (Teltijd - Starttijd1 <= DayIntterval) {
if (Teltijd - Starttijd1 <= 14400000) {
if (Teltijd - Starttijd4 <= RustInterval) {
digitalWrite(RelayAirPump, HIGH);
if (Teltijd - Starttijd2 <= AlgenMeetingInterval) {
Algenmeeting();
Starttijd2 = Teltijd;
else {
digitalWrite(RelayAirPump, LOW);
delay(1200000);
Starttijd4 = Teltijd;
if (Teltijd - Starttijd1 >= 14400000 && Teltijd - Starttijd1 <= 25200000) {
if (Teltijd - Starttijd3 <= PompjeIntervalNacht) {
delay(1200000);
else {
Starttijd3 = Teltijd;
Algenmeeting();
else {
Serial.println("UIT2 , UIT2"); delay(500);
delay(1200000);
if (Teltijd - Starttijd1 >= (39600000) && Teltijd - Starttijd1 <= (50400000)) {
delay(1200000);
if (Teltijd - Starttijd1 >= (50400000) && Teltijd - Starttijd1 <= DayIntterval) {
Algenmeeting();
else {
delay(1200000);
else {
Starttijd1 = Teltijd;
void Algenmeeting () {
int meetingsaantal = 3;
int teller = 0;
if (teller < meetingsaantal) {
if (teller = 0);
delay(20000); delay(20000);
float waarde01 = analogRead(A0);
float waarde11 = analogRead(A1);
float waarde21 = analogRead(A2);
Serial.print("SENSOR 1 WAARDE 1= " ); Serial.print(waarde01); Serial.print(" SENSOR 2 WAARDE 1= " ); Serial.print(waarde11); Serial.print(" SENSOR 3 WAARDE 1= " ); Serial.println(waarde21);
if (teller = 1);
float waarde02 = analogRead(A0);
float waarde12 = analogRead(A1);
float waarde22 = analogRead(A2);
Serial.print("SENSOR 1 WAARDE 2= " ); Serial.print(waarde02); Serial.print(" SENSOR 2 WAARDE 2= " ); Serial.print(waarde12); Serial.print(" SENSOR 3 WAARDE 2= " ); Serial.println(waarde22);
if (teller = 2);
float waarde03 = analogRead(A0);
float waarde13 = analogRead(A1);
float waarde23 = analogRead(A2);
Serial.print("SENSOR 1 WAARDE 3= " ); Serial.print(waarde03); Serial.print(" SENSOR 2 WAARDE 3= " ); Serial.print(waarde13); Serial.print(" SENSOR 3 WAARDE 3= " ); Serial.println(waarde23);
float gemiddelde_algen = ((waarde01 + waarde11 + waarde02 + waarde12 + waarde03 + waarde23) / 6);
float gemidelde_buiten = ((waarde21 + waarde22 + waarde23) / 3);
float constante = ((gemiddelde_algen / gemidelde_buiten) * 1000000);
float versturen = constante;
EEPROM_writeAnything(addr, versturen);
Serial.print("GEMMIDELDE ALGEN= " ); Serial.print(gemiddelde_algen); Serial.print(" GEMMIDELDE BUITEN= " ); Serial.print(gemidelde_buiten); Serial.print(" addr= " ); Serial.print(addr); Serial.print(" CONSANTE= " ); Serial.println(constante);
addr = addr + 5;
if (addr == EEPROM.length()) {
addr = 0;
delay(150);
else {
teller = 0;
return;
Sincerely,
Xander
