Why does my "for" loop only run once?
I have the following simple "for" loop:
void setup(){
  int i=0;
  for(i=0;i<=4;i++);{
  Serial.print(i);
void loop(){}
But when I watch the Serial Monitor, it only shows a "5." Why is it only running once?
Solved it. The extra ";" at the end of the "for" line causes nothing to happen. When I remove it, like this, it works:
void setup(){
  int i=0;
  for(i=0;i<4;i++){
  Serial.println(i);
void loop(){}
The misplaced or missing semicolon. :wink:
You have just repeated an error that lives in history, the great SS7 telephone switch cascade failure of January 1990, causing a 9 hour long distance outage. It's origin was in a failure recovery routine where a missing semicolon caused failure through around 100 ESS4 switches. And being a recovery routine of course became an infinite loop of failure! :sunglasses:
That is interesting. Any information links to the event available on the web?
Lefty
Actually, it didn't run just once. It ran 5 times. It just that each time did nothing except increment the value of i and use a few cycles of processing time.
stick a
in the code and you will see it count
@boffin1: you've missed the point - slowing the loop down will not show any numbers being printed, other than the terminal '5'.
You'll just have to wait longer to see it.
woops
yes I missed the point there, its in setup anyway
For hours of reading pleasure .... check Software Bugs - Software Glitches
  1. NASA Mariner 1 , Venus probe
    (period instead of comma in FORTRAN DO-Loop, 1962)
  2. AT&T long distance service fails for nine hours
    (Wrong BREAK statement in C-Code, 1990)
Rob
  1. AT&T long distance service fails for nine hours
This is great. I am going to quote this every time when somebody starts raving about how cool coding and computers are.
