I’m doing a collision avoidance (ultra range finder sensor)robot and when I have it plugged in to the usb it reacts just how I want it but when I just have the battery plugged in it acts like it can’t make a decision when it comes to avoiding obstacles. Why does it behave differently do to the power source and how can I fix it? could it have something to do with my code? Does anybody have any suggestions on improving the code I have thus far? my bot waits until it gets to the object to scan then move, it should be doing both on the fly in unison. Like I asked cn somebody give me some pointers on how i can improve this? And is it worth using a xbee modual along with my ultrasonic range finder?
#include <Servo.h> // Enables the Servo library
int E1 = 6; //M1 Speed Control
int E2 = 5; //M2 Speed Control
int M1 = 8; //M1 Direction Control
int M2 = 7; //M1 Direction Control
Servo PingServo;
//int IRsensor = 3; //IR interface
int pingPin = 11;//Ping sensor
int minSafeDist = 11 ; // Minimum distance for ping sensor to know when to turn
int centerDist, leftDist, rightDist, backDist; // Define variables center, left, right and back distance
long duration, inches, cm; // Define variables for Ping sensor
PingServo.attach(10); // Servo is attached to pin 10 in the motor shield
PingServo.write(90); // Center the Ping sensor (puts it at 90 degrees)
int i;
for(i=5;i<=8;i++)
//pinMode(M1, OUTPUT);
//pinMode(M2, OUTPUT);
Serial.begin(9600); // Enables Serial monitor for debugging purposes
Serial.println("Serial test!"); // Test the Serial communication
void stop(void) //Stop
digitalWrite(E1,LOW);
digitalWrite(E2,LOW);
void advance(char a,char b) //Move forward
analogWrite (E1,a); //PWM Speed Control
digitalWrite(M1,HIGH);
analogWrite (E2,b);
digitalWrite(M2,HIGH);
Serial.println("Going forward"); // Prints a line in the serial moni
void turn_R (char a,char b) //Turn Right
analogWrite (E1,a);
analogWrite (E2,b);
digitalWrite(M2,LOW);
delay(1600); // Time required to turn right (1.6 seconds)
Serial.println("Motors going Right"); // Prints a line in the serial monitor
void back_off (char a,char b) //Move backward
analogWrite (E1,a);
digitalWrite(M1,LOW);
analogWrite (E2,b);
delay(1600); // Time Required to go back (1.6 seconds)
Serial.println("Backward"); // Prints a line in the serial monitor
void turn_L (char a,char b) //Turn Left
analogWrite (E1,a);
analogWrite (E2,b);
delay(1600); //Time Required to turn left (1.6)Seconds
Serial.println("Motors going Left");// Prints a line in the serial monitor
LookAhead();
Serial.print(inches);
Serial.println(" inches"); // Prints a line in the serial monitor
if(inches >= minSafeDist) /* If the inches in front of an object is greater than or equal to the minimum safe distance (11 inches), react*/
back_off(240, 240);
}else // If not:
stop(); // Stop all motors
LookAround(); // Check your surroundings for best route
if(rightDist > leftDist) // If the right distance is greater than the left distance , turn right
turn_R(240, 240);
}else if (leftDist > rightDist) // If the left distance is greater than the right distance , turn left
turn_L(240, 240);
}else if (leftDist&&rightDist<minSafeDist) // If the left and right distance is smaller than the min safe distance (11 inch) go back
advance(240, 240);
delay(110); // Wait 0.11 seconds`cx3qqawA
unsigned long ping() {
pinMode(pingPin, OUTPUT); // Make the Pingpin to output
digitalWrite(pingPin, LOW); //Send a low pulse
delayMicroseconds(2); // wait for two microseconds
digitalWrite(pingPin, HIGH); // Send a high pulse
delayMicroseconds(5); // wait for 5 micro seconds
digitalWrite(pingPin, LOW); // send a low pulse
pinMode(pingPin,INPUT); // switch the Pingpin to input
duration = pulseIn(pingPin, HIGH); //listen for echo
/*Convert micro seconds to Inches
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
long microsecondsToInches(long microseconds) // converts time to a distance
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds) // converts time to a distance
return microseconds / 29 / 2;
void LookAhead() {
PingServo.write(90);// angle to look forward
delay(175); // wait 0.175 seconds
ping();
void LookAround(){
PingServo.write(180); // 180° angle
delay(320); // wait 0.32 seconds
ping();
rightDist = inches; //get the right distance
PingServo.write(0); // look to the other side
delay(620); // wait 0.62 seconds
ping();
leftDist = inches; // get the left distance
PingServo.write(90); // 90° angle
delay(275); // wait 0.275 seconds
Serial.print("RightDist: ");
Serial.println(rightDist);
Serial.print("LeftDist: ");
Serial.println(leftDist);
Serial.print("CenterDist: ");
Serial.println(centerDist);
